weird rubbing sound coming front right front - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 11-20-2008, 08:09 AM Thread Starter
Date registered: May 2008
Post weird rubbing sound coming front right front
I hear this weird rubbing sound coming from my right tire but it sounds like its coming from the inside of the tire it happens when i turn right go over bumps or starting to go from a light I just had both bearings replaced could that be it? help pls
johnsebik is offline
post #2 of 12 (permalink) Old 11-20-2008, 11:51 AM
Date registered: Jul 2007
Vehicle: 2002 CLK 430
I have no clue... but you might want to post more information, like any modifications to suspension/wheel size or just state that you're running 100% stock so that the people who do have a clue can help.
skiflyer is offline
post #3 of 12 (permalink) Old 11-20-2008, 01:08 PM
sfclk's Avatar
Date registered: Mar 2008
Vehicle: 1999 CLK320
Send a message via AIM to sfclk
do you hear the noise when braking only? accelerating? decelerating?
Sold 12/2009
18x8x235x40@et31, 18x9x275x35@et35, Eibachs, bilstein sports, #1 pad front & rear, resonator delete, flat hood emblem
sfclk is offline
post #4 of 12 (permalink) Old 11-21-2008, 05:31 AM Thread Starter
no modifications all original just had the bearing done though and did not here anything for a good month or 2 sounds like a creaky door opening when I am idle from a light when i go over bumps when i turn left etc
post #5 of 12 (permalink) Old 11-27-2008, 12:15 AM
gabidospi's Avatar
Date registered: Nov 2008
Vehicle: CLK 200 Sport (W208)
Unhappy
I have the same problem on my front left wheel. When I turn left, in shortly I have the impression that my wheel translating and not turning. I'm interesting on the answers. (CLK 200 w208 80000km, no modifications apart the bearing of that wheel - changed).
gabidospi is offline
post #6 of 12 (permalink) Old 09-10-2012, 12:55 PM
Date registered: Sep 2012
johnsebik
Did you manage to figure out what was causing the noise? Please let me know....THANKS!
idfk is offline
post #7 of 12 (permalink) Old 09-10-2012, 01:42 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 197 Post(s)
If you jack up the car, and spin the 'noisy' wheel - can you hear anything strange?
keyhole is online now
post #8 of 12 (permalink) Old 09-10-2012, 02:26 PM
Keyhole...
No, no noise from rotation while on a jack. I recently changed the front left wheel bearing. So i dont think it's that.
I know the noise is coming the tires/rim because, when the front left wheel was swapped to the right side, the noise went to the right as well. I just dont know what within the tire or rim could cause this noise. Wheel has been balanced and tire pressure checked.
My mechanic suggested the steel belt in the tire might have shifted. But i am skeptical with that answer....as i am very cautious when driving to avoid pot holes.
Stock car. 2008 c class (not 4matic)
Tires and rim - OEM
Thanks in advance!
idfk is offline
post #9 of 12 (permalink) Old 09-10-2012, 08:49 PM
Date registered: Apr 2006
Vehicle: 2000 CLK430 2010 S550 4matic
I seriously doubt its the tires. Techs always says this because they hate diag noises and things that aren't visably broken. If it was the tires belt they can see it when they spin balance the tire and the machine would report it.
Even though you jacked the car up the bearings are tapered - so you really need a load to determine if its dry or defective. It is rhythmic not a clunking sound - so its more than likely not the ball joints or steering linkage but you never know.
When the bearings were installed do you know if the nut was tightened really tight or finger tight - well sortof. For the CLK430 the front isn't super tight there is a slight amount of play on the tire at the 12/6 position. Read this in one of the tech manuals - but someone who has access to the WIS might shed some light here. This would do this as the bearing is probably binding. The bearing is going to be shot at this point as its going to put flat spots on the rollers in the bearing itself. If its backed off the spots are still going to be there and it will make another sound. Two years ago when my car was at a very good tire store I felt the wheels because I was having some sort of wobble at the front end. There was play. The techs there looked up the tech info and said there should be play. Dealership confirmed this - one of my wheels was slightly bent. Fixed that and the car has been perfect since.
stim141 is offline
post #10 of 12 (permalink) Old 09-10-2012, 09:00 PM
tbsi430's Avatar
Date registered: Oct 2004
Vehicle: 2000 CLK 430 Cab
"sounds like a creaky door opening when I am idle from a light when i go over bumps when i turn left etc "
Check your control arm bushings...I had a similar issue. Changed the bushings, noise disappeared.
tbsi430 is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > W208 CLK Class
User Tag List
Sound coming from front left wheel Bigburgundy W163 M-Class 9 11-19-2008 02:27 PM
sound coming from front wheel... gwml55 W163 M-Class 8 08-05-2008 12:08 AM
Creaking sound coming from front of car Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 0 05-16-2006 12:12 PM
rubbing sound in front wheel cnmcanelly W201 190 Class 7 02-12-2006 02:03 PM
Hearing A Rubbing Noise Coming From Right Front Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 0 09-28-2004 05:00 AM
