Old 09-20-2008, 12:37 AM   #11 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hey, DL.
This is a picture of the connector you're looking for:
Meister Eckhart
Old 09-20-2008, 08:44 AM   #12 (permalink)
Date registered: May 2005
Vehicle: 99CLK320
unplug
Hey gregs,
I have the visual on the pre cat sensor but trying to get it removed is the question. I can see how to remove it from the cat(if I had room) with a wrench but I can't figure out how to unplug it from the 4 plug cluster(that all four sensor leads converge)that ultimately leads to the ECU.
dlbehrns is offline   Reply With Quote
Old 09-20-2008, 12:07 PM   #13 (permalink)
Vehicle: 99CLK320
MarcusF, gregs et al
And......guess what? Stopped at the grocery store on the way home from work; when I came back out and started the car the CEL was out. Go figure!
Old 09-20-2008, 01:12 PM   #14 (permalink)
Formoque's Avatar
Date registered: Dec 2004
Vehicle: CLK 430 AMG
sounds like the o2 sensor to me also...
"I hear the colonal has grizzards"
Formoque is offline   Reply With Quote
Old 09-20-2008, 01:14 PM   #15 (permalink)
Formoque's Avatar
Talking i like your...
message!!! Nice
Originally Posted by gregs210 View Post
Hey, DL.
Old 09-20-2008, 02:09 PM   #16 (permalink)
Date registered: Sep 2006
Vehicle: 2004 CLK 240
There must be some kind of internal plastic clip holding the 4-pin socket in situ, otherwise it would drop out. It cannot twist because of the polarising groove that is clearly shown.
keyhole is offline   Reply With Quote
Old 09-20-2008, 09:10 PM   #17 (permalink)
Vehicle: 99CLK320
clip
found the clip/keeper and was able to unplug it. At least now I know I can get it off. Ordered the sensor even though the light went out. Don't trust it to stay out. Thanks one and all.
Old 09-27-2008, 06:39 PM   #18 (permalink)
Vehicle: 99CLK320
sensor replaced
two days before the sensor arrives, no CEL. on my way home from work the day it arrives the light comes on. I replace the sensor today and the light won't go out. Hmmm? Ordered a OBDII code reader that will erase codes so maybe that will do the trick? Anybody?
Old 09-28-2008, 06:57 PM   #19 (permalink)
Vehicle: 99CLK320
on top
just puttin' this subject back ontop to see if anyone will respond. Thx!
Old 09-30-2008, 07:18 PM   #20 (permalink)
Vehicle: 99CLK320
it's here
my code reader arrived today, hooked it up, scanned and got the same codes as autozone, erased the codes, the CEL went out. ta da! Now that the new o2 sensor is in.....let's see if the light stays off.
CEL=( kman230 W203 C-Class 5 08-09-2008 05:38 AM
CEL again! HELP!!!!! MBSLK230 R170 SLK Class 17 07-31-2008 12:06 AM
Cel penbed51 R170 SLK Class 9 12-27-2006 04:25 PM
Has your CEL just...... gsj224 W163 M-Class 1 05-17-2006 08:57 AM
Why I like my CEL gregs210 General Mercedes-Benz 5 03-06-2006 09:59 AM
