Old 08-15-2008, 12:50 PM   #11 (permalink)
A1EK's Avatar
Date registered: Sep 2005
Vehicle: W208 CLK230 Kompressor 2000 year, Brabus Monoblock VI, 15mm spacers, Eibach Pro Kit, Flat emblem
Originally Posted by CLK Operator View Post
Are the spring pads on the bottom of where the springs rest on the control arms? In both front and rear? This is something I'd be interested in doing.
nope they are on the top and the size is donated by the number of nipples you can just see at the edge where the spring fits inside the cup.
(I went from number #5 pad front and number #2 pad rear which was stock for me, to number #1 pad front and zero pad rear to get my drop just right.)
Do a search on spring pads there are 1000's of pages on this subject.
PS you should also get your front alignment adjusted if you alter the pads....
Good luck dood
18 x 225 x 40 on 8.5J & 18 x 255 x 35 on 9.5J Brabus Monoblocks VI reps
Eibach Pro lowering kit no # 1 pad front Zero rear. 15mm rear hubcentric
spacers, Flat emblem, Kompressor skirt badges
A1EK is offline   Reply With Quote
GPL on a C-Series C180 Benzin (95Kw) cobrain General Mercedes-Benz 1 05-08-2004 06:07 AM
Benzin Motor Works - Tulsa, Ok JFKennedy W210 E50 AMG, E55 AMG 0 05-20-2003 10:39 AM
Benzin Motor Works- Tulsa, OK JFKennedy W203 C32 AMG, C55 AMG 0 05-20-2003 10:38 AM
Benzin Motor Works - Tulsa, Ok JFKennedy W202 C36 AMG, C43 AMG 0 05-20-2003 10:38 AM
Benzin Motor Works - Tulsa, Ok JFKennedy W140 S-Class 0 05-20-2003 10:36 AM
