Old 07-17-2008, 12:18 PM   #1 (permalink)
deyainrdy4ds's Avatar
Vehicle: w208
Send a message via AIM to deyainrdy4ds
how to remove shiftknob
anyone know how to remove the shiftknob?
deyainrdy4ds is offline   Reply With Quote
Old 07-17-2008, 12:42 PM   #2 (permalink)
ZYALATR's Avatar
Date registered: Jan 2007
Vehicle: 1999 CLK 430
Send a message via AIM to ZYALATR
Black collar(bottom of shift knob) on steel shaft needs a twist
It will twist off and then pull off knob..
ZYALATR is offline   Reply With Quote
Old 07-17-2008, 02:32 PM   #3 (permalink)
A1EK's Avatar
Date registered: Sep 2005
Vehicle: W208 CLK230 Kompressor 2000 year, Brabus Monoblock VI, 15mm spacers, Eibach Pro Kit, Flat emblem
heres a bit more detail... At the bottom of the leather knob twist the plastic collar it will undo and move away from knob downward. Now just pull upwards on the leather knob to remove from shaft. Do not twist the knob around as it will do nothing...
18 x 225 x 40 on 8.5J & 18 x 255 x 35 on 9.5J Brabus Monoblocks VI reps
Eibach Pro lowering kit no # 1 pad front Zero rear. 15mm rear hubcentric
spacers, Flat emblem, Kompressor skirt badges
A1EK is offline   Reply With Quote
Old 07-17-2008, 08:26 PM   #4 (permalink)
Date registered: May 2005
Vehicle: 99CLK320
You may have to use a padded pair of channel locks to get the lower black collar to rotate about 90 degrees. I use old 10 speed bicylce inner tubes cut down to fit over the jaws of the pliers to keep from scratching up the plastic.
dlbehrns is offline   Reply With Quote
Old 07-17-2008, 09:26 PM   #5 (permalink)
Vehicle: w208
aight kool ill give it a try..thanks guys
Old 07-18-2008, 10:45 AM   #6 (permalink)
Date registered: Oct 2004
Vehicle: 2000 CLK 430 Cab
Just turn/twist the lower (black) plastic part (below the leather) counterclockwise about 1/8, then pull shift knob up. Should be able to turn the part by hand without plier, etc..
tbsi430 is offline   Reply With Quote
OEM shiftknob, leather, take a look! Guest (MBNZ) W124 E,CE,D,TD Class 1 01-13-2008 11:38 PM
Sportline Shiftknob 300e_sportline For Sale, Trade & Wanted Items 2 01-11-2008 10:12 AM
How to change shiftknob on 6MT? slktyperice R171 SLK Class 5 10-09-2007 03:45 AM
Brabus shiftknob Guest (MBNZ) W203 C-Class 0 01-26-2002 12:49 PM
FS: Brandnew OEM leather shiftknob with Advantgarde emblem...... Guest (MBNZ) W202 C-Class 3 10-14-2001 04:04 PM
