Old 07-15-2008, 12:51 AM   #1 (permalink)
enforcerman's Avatar
Date registered: Jun 2008
Vehicle: 99 CLK 430
ESP, ABS, and BAS malfunction... brake switch didn't fix, need help
Hi everyone,
I need a little help.
While an installer was installing an alarm, he was trying to tap into the brake's wire so the alarm would know when the brake is pressed.
I don't know what he did but now BAS, ABS, and ESP errors light up every time I start the car.
I told them to remove any wires they put next the the braking system and tried to solve the problem.
I've tried resetting the ECU - no dice
Installed new brake switch - no dice
Anyone have any more ideas?
I really appreciate it!
enforcerman is offline   Reply With Quote
Old 07-18-2008, 08:35 AM   #2 (permalink)
Vehicle: 99 CLK 430
so I bit the bullet and am at the dealership. I'll post results soon.
Old 07-18-2008, 10:16 AM   #3 (permalink)
Vehicle: 99 CLK 430
yep, so I just got romped by the dealer.
They just told me that a k40 relay was shorted. Part is ~$150 + 2 hrs labor...
totalling a good $440...
tech details for others:
the k40 relay controls power to both the steering angle sensor and the brake lamp switch.
Old 08-01-2008, 12:43 AM   #4 (permalink)
myia445's Avatar
Date registered: Jul 2008
Vehicle: 1998 CLK 320
Post ABS BAS/ASR
I was having this problem on my 98 and all I did was clean the front and rear speed sensors with a little electrical cleaner and presto, no more lights. So far so good, I only did it today but I restarted my car a bunch of times just to check. Hopefully this saves you a few bucks!
myia445 is offline   Reply With Quote
00 E430 BAS/ESP/ABS malfunction GregSoDak W210 E-Class 3 03-11-2008 01:07 PM
ESP-ABS-BAS Malfunction help please moaad001 W210 E-Class 11 09-26-2007 11:33 AM
ESP, BAS & ABS MALFUNCTION tnsr35 R171 SLK Class 11 09-01-2007 10:35 AM
BAS ABS ESP malfunction after tightening loose steering column sdjumin W210 E-Class 0 10-15-2006 05:43 PM
HELP ABS, BAS, ESP Malfunction Detected DGW203 W203 C-Class 6 04-28-2006 08:13 AM
