Old 07-08-2008, 02:46 PM   #1 (permalink)
Date registered: Apr 2008
Question plz... need help with handbrake problems
... after a big mistake i took my longer screws to mount the rear wheels and tryed to drive. I stoped immediately after i noticed a scratchy sound from the right rear wheel. Changing the screws to the normal shorter one was easy, but a scratchy noise was still present. Then i started to dismount the rear brake and took the disc off the axle ... i found a lost deformed spring behind the disc.
My questions are:
Where was that spring? How to get i back mounted and if it is not possible to repair that spring, is it possible to get only a new one?
Hope some of you guys can help me with that prob, cause i cant drive to the next dealer to get it fixed.
Here i added some pictures of that spring and the dismounted disc/handbrake:
kolbnfressa is offline   Reply With Quote
Old 07-08-2008, 11:45 PM   #2 (permalink)
sfclk's Avatar
Date registered: Mar 2008
Vehicle: 1999 CLK320
Send a message via AIM to sfclk
i'm not sure if parking brake shoes are on both sides, but...
did you check the other side?
sfclk is offline   Reply With Quote
Old 07-09-2008, 10:05 AM   #3 (permalink)
no i haven´t checked the other side but got it fixed. Was at MB, bought a new spring at mounted it on on the two holes with help of a picture i found in the net.
Further it shows the other side ... that should tell us there parking brake shoes are on both sides
help me plz convertible problems xenergiser2004x W208 CLK Class 1 04-25-2008 01:11 AM
help plz some problems aaraisi W202 C-Class 3 07-26-2007 06:42 PM
Having problems with fuel relays...help plz... Alexander.Veerapen W202 C-Class 2 09-21-2006 12:43 AM
Sound System Problems Plz Help ashkanyoussefi17 W203 C-Class 5 09-15-2006 12:26 AM
89 200 - Handbrake problems Gorbals89 W124 E,CE,D,TD Class 1 07-03-2006 06:02 AM
