Old 06-23-2008, 08:37 PM   #1 (permalink)
Date registered: Jun 2008
Radio Code Not Working
I have a 1999 clk 320 and unplugged the battery to install a brake lamp switch.
When it was plugged back in it asked for the code and i entered it but its
not working.
Any suggestions?
Thanks
mswee24 is offline   Reply With Quote
Old 06-23-2008, 11:13 PM   #2 (permalink)
Date registered: Sep 2004
Vehicle: 2000 CLK430 Coupe
not working.
Any suggestions?
Thanks
Is it the factory headunit? You can get the code from the dealer...might want to double check you have the correct one. Have you been able to use this code before? Be sure to hold the button down after the last number...
bs00clk is offline   Reply With Quote
Old 06-23-2008, 11:14 PM   #3 (permalink)
consumerpi's Avatar
Vehicle: CLK 55 Cabrio & CLK 430 Cabrio (Cabs or nothing)
What's the procedure to enter the code?
consumerpi is offline   Reply With Quote
Old 06-24-2008, 01:05 AM   #4 (permalink)
Date registered: Mar 2008
Vehicle: 2003 CLK500
i dont know it,but it should be in the manual.
<img src=http://www.benzworld.org/forums/images/smilies/tongue.gif border=0 alt= title=Stick Out Tongue class=inlineimg />
ZEEK is offline   Reply With Quote
Old 06-24-2008, 07:25 AM   #5 (permalink)
Yeah its the factory unit i called the dealership and got the same code i had before but still no luck.
What do you mean hold down the button after the last number? What button?
Old 06-24-2008, 08:18 AM   #6 (permalink)
A1EK's Avatar
Date registered: Sep 2005
Vehicle: W208 CLK230 Kompressor 2000 year, Brabus Monoblock VI, 15mm spacers, Eibach Pro Kit, Flat emblem
...you just need to hold down the right dial crazy man and it will work!!
Therefor enter the code and when all entered then push and hold in the right dial for 3 secs... Its all in the manual !
18 x 225 x 40 on 8.5J & 18 x 255 x 35 on 9.5J Brabus Monoblocks VI reps
Eibach Pro lowering kit no # 1 pad front Zero rear. 15mm rear hubcentric
spacers, Flat emblem, Kompressor skirt badges
A1EK is offline   Reply With Quote
Old 06-24-2008, 04:55 PM   #7 (permalink)
in mine it just says enter the 5 digit code. Confirm by pressing "ok" key. But thats doesnt work.
So what is the right dial?
Old 06-25-2008, 03:25 AM   #8 (permalink)
A1EK's Avatar
Simply enter your 5 digit code and press and hold in the dial...
See photo! if you still cant figure it out, take it to a dealer, its free !
Old 06-25-2008, 07:20 AM   #9 (permalink)
see my radio isnt like that its the one with the numbers on the right side like in this http://i6.ebayimg.com/08/i/000/f9/45/9141_1.JPG (6 cd changer)
when i called the dealership for the code thinking that i got the wrong code from the previous
owner they gave me the exact some code and when i said it didnt work they said that
id have to bring it in and it could be a after market one and that they would have to take
the whole stereo out and all this crap.
could it be a wire is loose somewhere when i installed the brake lamp switch?
Old 06-25-2008, 09:36 AM   #10 (permalink)
consumerpi's Avatar
This is crazy! I was about to swap out the battery and now after reading all of this (even though I have what I think is the code), I may get one of those devises that plugs into the cigarette lighter to retain the power - although now that I think about it, doesn't MB cars only allow you to use the cig lighter if the ignition is in the "on" position and not shut off?
Does the Audio 20 have a radio code? - NOT a code request!! TomTanderson Audio & Telematics Forum 2 02-09-2008 03:00 AM
Code blinkning on the radio? Won't take the code. johny74 W202 C-Class 1 08-28-2007 09:34 PM
Radio code NOT WORKING!!!! PLEASE HELP!!!!!! Veloce300DT Audio & Telematics Forum 1 11-17-2006 05:37 PM
radio not working after battery disconnect- not code related! heron25 Audio & Telematics Forum 9 02-03-2006 12:25 AM
radio code 95 original e320 radio Guest (MBNZ) Audio & Telematics Forum 1 06-04-2002 07:11 AM
