I would say something it not right, as - 38oC is -36oF ?!
By the way, I thought people in the US used Farenheit more then Celcius~?? next your by changing the speedo to Kilometers !
__________________ 18 x 225 x 40 on 8.5J & 18 x 255 x 35 on 9.5J Brabus Monoblocks VI reps
Eibach Pro lowering kit no # 1 pad front Zero rear. 15mm rear hubcentric
spacers, Flat emblem, Kompressor skirt badges
lol no 36oC is not -36oF. 36oC is about 92oF. The temp that our car shows is outside temp, just try messing aroudn with the settings and im sure you can change it to Fo and then turn the car on in night day or whatever to see if the temp changes.
Guys.......the temp stays at those figures and does not change at all when driving the car even up to operating temperature - day or night. number does not change at all.
The outside temp sensor is located in your front bumper behind the diffuser next to fog light, probably driver's side (it is on my 01 w208 anyway). It's about 2 1/2 inches long and about as big as a magic marker at the base and then tapers to a point (looks like a cone). You can get them anywhere. I have an extra. They are pretty cheap. Worth a shot to narrow it down anyway. However, we all have pixel 'issues' in one way, shape, or form. Maybe this is your dash starting to mess with you ???? Definitely check the sensor first. Really really easy to change. 1 minute. I hope this helps.
-John
__________________ --John
2001 CLK55 AMG
18" Mandrus Millenium wheels
Resonator Delete
Green Filters H&R Sport Springs and 1 bump cups on all 4 corners
