» Site Navigation
» Other Sites
Old 06-23-2008, 08:44 AM   #11 (permalink)
consumerpi's Avatar
Vehicle: CLK 55 Cabrio & CLK 430 Cabrio (Cabs or nothing)
Okay, so, it turns out that the temp reading for outside temp reads properly on the Climate Control unit, but the Instrument cluster (Speedo unit) still is "stuck" at "-38".
So, would I assume that the sensor under the car is working but the cluster is not picking it up? Any idea if both the Cluster and Climate Control gets the temp reading from that same temp sensor under the front of the car?
I love teh car, but that reading is annoying.
Originally Posted by da_guitarist View Post
its definitely sensor related. Mine is that way too now...i get -36. I need to drop it off at the dealership and let them fix it one day soon.
consumerpi is offline   Reply With Quote
Old 06-23-2008, 04:59 PM   #12 (permalink)
da_guitarist's Avatar
Date registered: Aug 2006
Vehicle: 01 CLK55
one of these days i'm gonna take it in to the shop. haven't gotten around to it. off topic, but do you have axis milano wheels? maybe monet gothic? looks like that's whats in your avatar
da_guitarist is offline   Reply With Quote
Old 06-23-2008, 09:48 PM   #13 (permalink)
consumerpi's Avatar
Yep, Axis Milanos. There're about to replace the puny 17's on my CLK55 Cab that I just picked up. Have them on my CLK 430 Cab right now and have had lots of compliments.
Best wheels ever. Any car that I get from now on will have Axis Milanos even if I have to make them fit. Love em! Ho do you like yours?
Old 06-24-2008, 05:16 AM   #14 (permalink)
unlukky's Avatar
Vehicle: 2001 CLK55 AMG (1 of 1,313 in U.S.)
Post
Unfortunately, I don't know if the CC unit reads off the same as the dash display. My first inclination is yes, but without a print, I couldnt say for sure. If out of warranty, I would change that sensor before anything. (It IS that cheap and THAT easy). If under warranty, I would def bring it in. Unless dealer was a long way away ( gas prices ). then I would still change that sensor first. You dont even need tools.
--John
2001 CLK55 AMG
18" Mandrus Millenium wheels
Resonator Delete
Green Filters
H&R Sport Springs and 1 bump cups on all 4 corners
unlukky is offline   Reply With Quote
Old 06-24-2008, 05:30 PM   #15 (permalink)
Vehicle: 01 CLK55
I think they're fantastic. Low priced, pretty lightweight, reliable so far, and absolutely stunning looks. I'm getting ready to do a facelift and some custom paint on them b/c I don't want a different spoke styling. In my opinion they're pretty close to the perfect fit for the 208's.
Old 06-30-2008, 02:15 PM   #16 (permalink)
Vehicle: 01 CLK55
So i was under my car changing the oil this weekend and found that my sensor had come unplugged. Could be your problem too. The sensor is on the inside of the bumper, on the drivers side, close to the center. it has 2 wires and a connector. I think the wires were brown and orange or brown and green or green and orange. if its plugged in, unplug it and make sure the terminals are clean.
Old 07-20-2008, 11:37 PM   #17 (permalink)
consumerpi's Avatar
Thanks. Will be doing an oil/coolant/thermostat change next weekend, so I'll be checking this as well.
Old 07-20-2008, 11:38 PM   #18 (permalink)
consumerpi's Avatar
Totally agree! Perfect fit for a CLK.
new ac problem cabin temp sensor jimwex W208 CLK Class 0 07-17-2007 05:31 AM
Outside Temp Reads 101 Intermittently Mr Hemi Head R171 SLK Class 6 11-30-2005 08:54 PM
outside temp. is celcius; wanting fahrenheit andthestoryends W126 S,SE,SEC,SEL,SD,SDL Class 9 09-26-2005 11:29 AM
A/C PROBLEM EVAPORATOR TEMP SENSOR? 93 BENZ S400SEL W140 S-Class 2 09-20-2005 06:54 PM
Changing Temp from Celcius to Farenheit. Guest (MBNZ) W202 C-Class 1 12-05-2001 07:51 PM
