Old 05-26-2008, 08:32 PM   #11 (permalink)
big_mike1979's Avatar
Date registered: Oct 2006
Vehicle: clk320
Originally Posted by racelance View Post
Mike-
Man... you're great at spending my money today! :-)
Thanks,
Lance
PS Where did you purchase your spacers. I'll probably just order them now, if I don't use 'em I'll just sell them on this site.
JUST DO IT RIGHT LANCE.
i havent bought them but i looked them up(and gettin slotted and half drilled rotors and gonna install em after i come back from vegas on june 23 ), 2mmrow will pm u the link since we cant advertise here i think....
big_mike1979 is offline   Reply With Quote
Old 05-26-2008, 08:34 PM   #12 (permalink)
Vehicle: clk320
Originally Posted by sfclk View Post
If you can't find wheels that would fit flush, spacers are fine. I personally don't like installing spacers.
bro if u lower the car like i did, the rear sinks in more than the front..look up the pic of my car and u will see what im talking about. unless u did not lowered and only had rims, then the car should look fine.
correct me if im wrong!!!
Old 05-26-2008, 08:38 PM   #13 (permalink)
Vehicle: clk320
Good to know - thank you. Do you have any pics of your car?
Thanks,
Lance
i think rashman has spacers wt 15mm...
Old 05-27-2008, 03:26 AM   #14 (permalink)
gizzo's Avatar
Date registered: Apr 2004
Vehicle: 89' 190e 2.6 / 02' CLK55 AMG
I definatly want to bring out my rear more.
Suggestions on make and brands?
Vogtland Springs / Bilstein Sport
OZ 18x8" Ultraleggera lightweight (18.3 lb)
Green Filters
Calibre K40 Radar/Laser Jammer
gizzo is offline   Reply With Quote
Old 05-27-2008, 11:38 AM   #15 (permalink)
da_guitarist's Avatar
Date registered: Aug 2006
Vehicle: 01 CLK55
I have H&R spacers and they are great. I don't think you need spacers for your application, but it might look better with some. Probably not more than 10mm tho. do the research, i'm not positive going from memory. i think mine are 35 offset rear w/ 10 mm spacers. they fit very nicely. make sure the spacers are HUBCENTRIC (have a centering ring)
da_guitarist is offline   Reply With Quote
Old 05-27-2008, 03:02 PM   #16 (permalink)
Rashman's Avatar
Date registered: Nov 2007
Vehicle: '01 Avantgarde CLK 230 Kompressor
Originally Posted by redflames View Post
is it bad not to have hubcentric spacers??
YES!
Hubcentric spacers are designed to fit snuggley against both the wheel and the hub.
Normal spacers, which are basically big washers, are prone to moving around alittle causing noises or vibrations.
Hubcentric spacers are worth the money.
Rashman.
____________________
19" replica Carlsson 1/16 rims
Eibach ProKit
Koni adjustable sport dampers
20mm SCC Hubcentric Spacers
Blue LED interior lighting
Green Induction Kit
SuperSprint backbox
Front camber adjust
#2 front spring pads
Flat Bonnet badge
Side trim Kompressor badging
Blue Calipers, Hubs & Disc Guards
Rashman is offline   Reply With Quote
Old 05-27-2008, 07:40 PM   #17 (permalink)
Vehicle: clk320
how would i know if i want 15 or 10 mm..... i see some peeps have 10 and some 15....
Old 05-27-2008, 07:41 PM   #18 (permalink)
Vehicle: clk320
HR spacers
Old 05-27-2008, 08:31 PM   #19 (permalink)
Suzy Snowflake
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK GoPed Freightshaker & Volvo semi's, c'mawn?
10mm will bring the top of tires flush with the arc of the fender and give the lower portion an aggressive look with the curvature of the bumper. Any more that 10mm would make the tire stick out and look silly imho. You will also have to get lugs that are that much longer.
-Pointless liar and inventor of the Bizzy Buzz Buzz.
Silence is Golden, Duct Tape is Silver.
ThrillKill is offline   Reply With Quote
Old 05-27-2008, 08:46 PM   #20 (permalink)
deyainrdy4ds's Avatar
Vehicle: w208
Send a message via AIM to deyainrdy4ds
thrilkill, so if i just throw on 10mm spacers in my rear, you dont think ill need new lugs/locks?
deyainrdy4ds is offline   Reply With Quote
Spacers Question help please maxwerks W210 E50 AMG, E55 AMG 2 12-04-2007 01:33 PM
question about spacers for anyone especially FRANK Phade W208 CLK Class 0 11-08-2005 05:59 PM
Spacers... nasdakboy W203 C-Class 4 03-06-2005 09:59 AM
spacers ruik7 W208 CLK Class 2 08-22-2004 02:53 PM
Luke, question on spacers for an E55 AtlasDC The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 10-21-2003 11:47 PM
