Old 05-12-2008, 11:30 AM   #31 (permalink)
regsatx's Avatar
Date registered: Sep 2004
Vehicle: 1985 300SD•2001 CLK 430•1988 560SL
Thanks Tbsi430, But I Figured It Out!
You are right about having to manually adjust the needles. Actually, I had to move both the tach and speedo needle all the way past the clockwise stop to about the amount of distance they were off (car was idling slightly below zero, and speedo was off about five or six miles from the digital speed readout. I had the cluster connected but out of shell while doing these adjustments because they have to be fine tuned to get just right. I finally got all needles back to where they belong...YES!!!
So screw the pixel display for now! My beautiful CLK is back to where it was before I started what I'm gonna call Saturday's "Cluster F**K" marathon. Still pissed at MB for designing it that way and hopefully they will HAVE to fix these one day. Till then, I've got some nice watches to tell time and from now till October where I live the temp is gonna be simply HOT!
regsatx is offline   Reply With Quote
Old 05-14-2008, 05:17 PM   #32 (permalink)
babyboigsxr's Avatar
Date registered: Feb 2008
Send a message via AIM to babyboigsxr
Does anyone know what LED Bulb sizes are needed to for the gauge cluster?
If anyone can post the bulbs size with the corresponding area, i'd really appreciate it.
- Clock ===> ?
- Mileage ===> ?
- Temp ===> ?
- Back-lighting ===> ?
Thanks in advance.
BaByBoiGsxR
babyboigsxr is offline   Reply With Quote
Old 05-15-2008, 06:16 AM   #33 (permalink)
Date registered: May 2008
I want to try your 'fix' - but need advice on the instrument cluster removal from my '02CLK 320.
braimoh123 is offline   Reply With Quote
Old 05-15-2008, 04:07 PM   #34 (permalink)
Mr. Pie's Avatar
Date registered: Nov 2004
Vehicle: CLK320 / E500
Send a message via MSN to Mr. Pie
The search works great fo these types of questions
2001 W208 Black Opal Metallic
K2a, K3, K4 + COMAND, HID halo projector headlights, flat hood emblem, chrome cluster rings, Bluetooth phone adapter, MB illuminated door sills, AMG steering wheel, AMG pedals, chrome AMG II dual spoke wheels, Nitto NT 555 Extreme Performance, 235/35/19 front, 265/30/19 rear
2004 W211 Platinum Blue Metallic
Premium Package, Apperance Package, Keyless Go, Bluetooth puck and tail
Mr. Pie is offline   Reply With Quote
Old 05-27-2008, 11:51 AM   #35 (permalink)
Date registered: Jul 2007
So, I took my cluster back out to fix the gas gauge... all is good. I have full clock, full temp, and all but 2 pixels on the shift readout.
Gas gauge needle is back to operational as well as the light leakage I had. Here's the "needle issue" in a nutshell. Either when you release the back plastic piece or when you release those other circuit board pins it's very easy to unclip the dials as well.
That goes for the speedo, the tach and the gas/temp dials. So, a quick push on the face of the gas/temp dial and all was good. As a visual cue, the tach and the gas/temp dials should be a couple millimeter *behind* the speedo dial. Flush is not right, and in front of the speedo will cause the needles to stick, as well as ambient light to leak into warning areas.
My advice is to connect the wires after you've snapped on the back plastic and start the car, verify all dials work right, and then disconnect and snap on the front.
Hope this helps someone!
skiflyer is online now   Reply With Quote
Old 06-13-2008, 06:49 PM   #36 (permalink)
Date registered: Jun 2008
Did it, but need some advice on ribbon cables
Thank you, Franasia, your instructions were excellent - really top notch.
Unfortunately it did not work for me.
I followed the instructions exactly, and all seemed well but when I re-installed the IC there was no change at all in my intermittent/non-working temperature and clock/shift displays. ALSO the fuel gauge would not work. I discovered that the mouse pad material I used was too thick and causing the fuel gauge motor to bind.
I found a thinner mouse pad and installed that - fuel gauge worked fine, but still no effect on the temperature and clock/shift displays.
So I tried again this time with the alternate Foam block method but no effect.
Finally, I reached behind the ribbon cable with a smooth stick (actually a nice clean smooth chopstick!) and rubbed gently on top of the ribbon cable connectors. Reassembling with the thinner mouse pad material I found that the problem was not solved but slightly changed in that some different elements of the LCD worked while ones that had previously worked now did not work.
I am now an expert at removing the instrument cluster and dismantling & reassembling because I have done it about 5 times.
SO - if you're still with me - I have an idea: I think the ribbon cable connectors are corroded and I will need to disconnect the ribbon cables and clean the contacts, then reassemble using Franasia's method with the the thin pad material.
Has anyone done something like this before?
Will I be able to reconnect the ribbon cable if I completely disconnect it?
Will it be possible to precisely align the ribbon cables so that the connectors line up with the circuit board connectors?
Any advice greatly appreciated.
Thanks
bdear115@aol.com is offline   Reply With Quote
Old 06-14-2008, 04:12 PM   #37 (permalink)
Is anyone interested in a used '01 CLK 320 CLUSTER?
i bought a BRAND NEW ONE online and had it installed at the dealer for a total of $342
EVERYTHING WORKS except for THREE LINE PIXELS in the clock area. No scratches or anything. it's perfect. Only has... 97,600 miles on it.
Hit me up.
Old 06-26-2008, 03:28 PM   #38 (permalink)
bankerkys's Avatar
Date registered: Nov 2007
Vehicle: 2002 CLK430, 2007 FJ Cruiser TRD
Wish I would have tried this before spending $275.
bankerkys is offline   Reply With Quote
Old 08-01-2008, 11:03 AM   #39 (permalink)
Date registered: Aug 2008
Not clear about the key / ignition
Hello,
I'm excited about this weekend's project. Thank you again for this awesome post!
However, this is my first trip down DIY lane on my E430, and I don't understand what others have said about the key in the ignition. So: do I put the key in the ignition while doing this job, or do I not? I understand the key in the ignition keeps things live while the battery is changed, does it also keep the cluster settings (miles, etc)?
Thank you!
RadicalCraig is offline   Reply With Quote
Old 08-03-2008, 11:17 AM   #40 (permalink)
Lcd repair caution
Originally Posted by Franasia View Post
Hi everyone,
Just put together this fix for the cluster pixel problem most of us are familiar with that I was able to do on my wagon. It covers the temp and clock displays fix. I posted it on the W210 section and figured I would post it here as well.
Enjoy
Hi I tried your fix, it worked pretty well when I tried it the first time, thought I could make it a little better with a little more pressure. Now it is worse than before I started.
I was able to make a tool to get the cluster out very simply by takeing a little flat piece of metal that I had and bending a little lip on it. Then you can slide it between the cluster and the dash and pull out the cluster a little at a time from each side. The other thing is how to remove the eletrical connectors on the back. There is a little gray clip that has to move and a little black stopper that you must push down in order to make the gray clip move to one side in order to remove the connector. I guess what I am going to have to do is take this to a speedomoter shop or electrical shop and have the little sprips re attached. Thanks anyway.
ablnc@triad.rr.com is offline   Reply With Quote
DIY: Instrument Cluster LCD Display Fix with Pictures Franasia W210 E-Class 18 09-29-2008 04:18 PM
Instrument Cluster Replacement-Clock Display Stopped Working Dragon986 W163 M-Class 6 02-17-2008 05:13 PM
Testing the digital display instrument cluster ErikFinn R129 SL Class 0 06-28-2007 02:15 AM
E320 Instrument cluster display faults NippyNelmo W210 E-Class 14 04-04-2006 01:50 PM
DIY on instrument cluster light bulb change ?? Guest (MBNZ) W210 E-Class 3 01-17-2003 12:06 PM
