Old 04-18-2008, 12:39 PM   #1 (permalink)
zMackeyCLK430's Avatar
Date registered: Feb 2008
"Clunk" sound at slow turns....
I hear a "clunk" sound when I turn slowly. It is coming from the front of the car. Anyone know what it might be? Where should I start checking?
"..I have seen the others and I have discovered that this fight is not worth fighting.."
zMackeyCLK430 is offline   Reply With Quote
Old 04-18-2008, 05:47 PM   #2 (permalink)
CLK MAN's Avatar
Date registered: Feb 2007
I have the same problem now and I had it before.
It's the inner or outer tie rod. If it's the inner you have to buy the whole drag link assembly...if it's the outer you can buy separate tie rods. Go to a alignment shop and have check for you because they both make the same noise when they have failed.
I fixed mine when it was the inner and I bought the entire drag link...was about $279 for the part and it was fixed but now the problem has returned....I think it's a design flaw in these cars.
If you get this fixed you should also get a new steering dampener while you're at it because it will make your steering feel much nicer.
"If everyone thought the same when it came to modding there would be no thinking"
CLK MAN is offline   Reply With Quote
Old 04-18-2008, 06:05 PM   #3 (permalink)
Rashman's Avatar
Date registered: Nov 2007
Vehicle: '01 Avantgarde CLK 230 Kompressor
Hi.
It might also be an idea to check your springs.
A while ago, I too had a "clunking" noise as I made slow turns.
I discovered that one of my rear springs had snapped about 2 inches from the bottom. The clunking noise was the sound of the spring moving around on top of the broken piece as the suspension travelled. My guy at MB said that this is fairly common, more so in extreme conditions/ weather.
I have since installed Eibachs.
This may not be the cause of your noise, but just a thought.
Rashman.
____________________
19" replica Carlsson 1/16 rims
Eibach ProKit
Koni adjustable sport dampers
20mm SCC Hubcentric Spacers
Blue LED interior lighting
Green Induction Kit
SuperSprint backbox
Front camber adjust
#2 front spring pads
Flat Bonnet badge
Side trim Kompressor badging
Blue Calipers, Hubs & Disc Guards
Rashman is offline   Reply With Quote
Old 04-18-2008, 06:13 PM   #4 (permalink)
Date registered: Aug 2007
Vehicle: 2003 CL500
Hmmmmm..... I have been hearing the SAME sound in a w215..... Drove me crazy but havent heard it lately. Only on sharp left turns
ALi
goliath27 is offline   Reply With Quote
Old 04-18-2008, 08:47 PM   #5 (permalink)
Vehicle: 2000 Clk430
Interesting... i have this same sound
I had my drag link replaced a year ago, and curious how much a new steering damper would cost?
thanks
humplok is offline   Reply With Quote
Old 04-18-2008, 08:54 PM   #6 (permalink)
zeronine's Avatar
Date registered: Apr 2008
Vehicle: 2002 CLK430 Coupe
I had a similar sound when I turned left and it turned out to be the combination of a loose motor mount and sway bar. It was a kind of popping sound that would happen a 2-4 times while the wheel was turned. You may also have the shop check the ball joints and bushings on the suspension joints and sway bars just to be sure.
zeronine is offline   Reply With Quote
Old 04-20-2008, 11:32 PM   #7 (permalink)
sfclk's Avatar
Date registered: Mar 2008
Vehicle: 1999 CLK320
Send a message via AIM to sfclk
thanks
about $30 from mercedesshop.com
sfclk is offline   Reply With Quote
Thompson the "outsider" turns out to be the ultimate insider FeelTheLove Off-Topic 12 07-03-2007 01:40 PM
Bush Turns in to Franklin D. with a "New Deal" Plan for Iraq Jakarta Expat Off-Topic 5 12-24-2006 08:35 AM
NE1 have their SLK make a "clunk" sound when they 1st get in the car (more) DaveS R170 SLK Class 6 06-20-2006 03:44 PM
Clunk sound during bumpy right turns JoeBlow W163 M-Class 3 07-22-2005 05:56 AM
