Old 04-17-2008, 10:21 PM   #1 (permalink)
Date registered: Nov 2007
Bad noise from the back
When ever the back raises or hits a big bump i hear this lunk sound. I was thinking the shock could be bad but the car is not bouncing nor does it happen on reg driving. Ride height is still the same. Do our cars have a rear shock mount? And how expensive are new rear shocks? I was looking up shocks and it was saying one side is more expensive then the other side. Can anyone elaborate?
soby is offline   Reply With Quote
Old 04-19-2008, 12:16 AM   #2 (permalink)
sfclk's Avatar
Date registered: Mar 2008
Vehicle: 1999 CLK320
Send a message via AIM to sfclk
I think I am hearing the same noise. I recently replaced spring pads and shocks with #1 and bilsteins sports all around.
I'll let you know if I find the noise.
sfclk is offline   Reply With Quote
Old 04-19-2008, 12:55 AM   #3 (permalink)
~BANNED~
linh's Avatar
Vehicle: 06' CLK 500 Cabrio, 01' CL 55, 01' CLK 430, 04' Civic
Originally Posted by sfclk View Post
I think I am hearing the same noise. I recently replaced spring pads and shocks.
Who installed your shocks? Did they re-installed the factory rubber bushing that goes on top of the shock back? Without this rubber bushing, it will cause metal to metal thumping noise. Each shock should have two bushing. One goes on top of the shock and the other goes on top of the chassis. Bilstein shock only came with one bushing and it the one that goes on top of the chassis.
linh is offline   Reply With Quote
Old 04-19-2008, 10:23 AM   #4 (permalink)
sfclk's Avatar
The bilstein sports I got from tirerack came with a bushings for the top nut and washer and a thinner bushing for the chassis and shock. I did not install a bumpstop though.
Old 04-20-2008, 06:52 AM   #5 (permalink)
It is a stock set-up, I think the shocks just went. IM going to go with the H&R touring kit. Thanks though
Old 04-20-2008, 10:04 AM   #6 (permalink)
sfclk's Avatar
I sourced the noise to a sway bar link. I overtightened the lower nut that connects to the lower arm. Does anyone have a torque spec for that nut?
Old 04-20-2008, 03:24 PM   #7 (permalink)
Date registered: Jul 2007
I think I have the exact same issue. No bouncing, but a "kloklonk" noise coming from the rear left side.
I will probably replace both rear shocks... but I still have some doubts.
1. Did you find where your noise was coming from?
2. What brand of shock do you recommend. My local part supplier only carry monroe. Is it something to avoid at all costs? Would it make a big difference compared to something else? I always wondered if the handling of a car depends more on the quality of the parts, or the geometry of the design. I mostly drive in town and on dirt road.
C230K 2002
avecuny is offline   Reply With Quote
Old 04-20-2008, 11:14 PM   #8 (permalink)
sfclk's Avatar
the rear shocks mount directly to the chassis.
Old 04-21-2008, 08:01 AM   #9 (permalink)
Date registered: Oct 2004
Vehicle: 2000 CLK 430 Cab
Happened to me. Check your spring link bushings (rear)... they could be cracked.
tbsi430 is online now   Reply With Quote
Bad misfire is back and no codes, any ideas GDC W124 E,CE,D,TD Class 11 02-07-2008 08:00 AM
A Very Bad Noise ScottinSoCal R/C107 SL/SLC Class 79 07-04-2007 10:08 AM
bad noise mr diesel W123 E,CE,D,CD,TD,TE Class 0 05-29-2005 10:34 AM
ML back from the dealer, and it's bad... BenjiBoy650 W163 M-Class 26 01-24-2004 07:34 PM
really bad noise on and off blackbenz87 W163 M-Class 31 01-01-2004 11:40 AM
