Old 04-12-2008, 05:47 PM   #1 (permalink)
Date registered: Jun 2005
Angry DO NOT BUY SHIZZIT FROM DIYAUTOPARTS.COM !!!
I bought a Mass Airflow Sensor (MAF) from this outfit and they sent me a defective unit. I replaced the Air Filter anf the MAF. Approximately every other day after replacing the unit I would again throw the same P0170 & P0173 codes. I call up this oufit to advised that I was still throwing a P0170 & P0173 code after replacing the MAF and the guy went " we sell a bunch of those MAF and have not had one returned yet" Duh!! there is always a first. The guy was basically busting my balls and told me he was not gonna take the unit back because anything can throw that P0170 & P0173 code and wanted to know who is my mechanic and which diagnostic system I used to diagnois the vehicle.
To make a long story short I disputed the charge on my credit card and bought another unit from Autohauz.com and replaced the defective one from DIYAUTOPARTS.COM and problem fixed immediately. I have not seen the CEL in @ a month and NO P0173 & P0173 code present when checked.
Stay away from DIYAUTOPARTS.COM they do not back their product.
sazodada is offline   Reply With Quote
Old 04-12-2008, 05:53 PM   #2 (permalink)
babyboigsxr's Avatar
Date registered: Feb 2008
Send a message via AIM to babyboigsxr
Arrow
Good thing you posted this up. I was planning to replace mine.
By the way, for anyone else who reads this thread/post...
How often or when are you normally suppose to change your Mass Air Flow Sensor?
BaByBoiGsxR
babyboigsxr is offline   Reply With Quote
Old 04-12-2008, 08:56 PM   #3 (permalink)
Date registered: May 2005
Vehicle: 99CLK320
MAS
replace it when it goes out. there's no scheuled change that I am aware of. Maybe Marcus can jump in on this one.
dlbehrns is offline   Reply With Quote
Old 04-13-2008, 06:28 AM   #4 (permalink)
Formoque's Avatar
Date registered: Dec 2004
Vehicle: CLK 430 AMG
i do believe they don't have s expiration date, but check your owners guide to be sure...but you'll know when you get a error?
"I hear the colonal has grizzards"
Formoque is offline   Reply With Quote
Old 04-13-2008, 06:40 AM   #5 (permalink)
Thats right there is no scheduled change interval. My MAF went out at 166K miles. Make sure you change the air filter also and use an OEM BOSCH brand because mine did not like that aftermarket brand MEYLE, it's a bit cheaper but save y'self the headache IMHO.
Old 04-13-2008, 10:46 PM   #6 (permalink)
bankerkys's Avatar
Date registered: Nov 2007
Vehicle: 2002 CLK430, 2007 FJ Cruiser TRD
Thanks for the tip. I changed my MAF at 30,000 miles to see if throttle response would improve. It worked.
I got my MAF off E-Bay from a terrific vendor - jskunca
bankerkys is offline   Reply With Quote
Old 04-13-2008, 10:59 PM   #7 (permalink)
sfclk's Avatar
Date registered: Mar 2008
Vehicle: 1999 CLK320
Send a message via AIM to sfclk
good to know it's not as expensive as some mafs...$173 shipped from autohausaz.
sfclk is offline   Reply With Quote
Should I buy a S500 that has been a manufacture buy back? dmtza W220 S-Class 12 04-03-2008 09:48 PM
If I was to buy a parts car for you guys, would you buy? CharlesAFerg W140 S-Class 4 01-31-2007 05:04 AM
2005 E55: to buy or not to buy, that is the question chutia W211 E55 AMG, E63 AMG 2 11-07-2006 12:32 PM
88 560sel with single valve tap..buy or no buy? IceBlue_1980_300TD W126 S,SE,SEC,SEL,SD,SDL Class 9 12-15-2005 12:48 PM
Advice needed on 1993 500SEC... to buy or not to buy? Guest (MBNZ) W220 S-Class 2 05-30-2002 08:23 PM
