Old 04-12-2008, 05:03 AM   #1 (permalink)
Rashman's Avatar
Date registered: Nov 2007
Vehicle: '01 Avantgarde CLK 230 Kompressor
Rear camber
Hello people.
I need some advice/ information on adjusting the rear camber. I have had the front adjusted and was told that the rear cannot be adjusted. I know this to be incorrect.
What will adjusting the rear camber involve?
I also need to find a company in the UK that can supply what I need.
Any help will be much appreciated.
Thanks all.
Rashman.
____________________
19" replica Carlsson 1/16 rims
Eibach ProKit
Koni adjustable sport dampers
20mm SCC Hubcentric Spacers
Blue LED interior lighting
Green Induction Kit
SuperSprint backbox
Front camber adjust
#2 front spring pads
Flat Bonnet badge
Side trim Kompressor badging
Blue Calipers, Hubs & Disc Guards
Rashman is offline   Reply With Quote
Old 04-12-2008, 10:48 AM   #2 (permalink)
deyainrdy4ds's Avatar
Vehicle: w208
Send a message via AIM to deyainrdy4ds
Originally Posted by Rashman View Post
Hello people.
Thanks all.
u need a camber kit...go with KMAC ...most members use that brand..im gettin mine put on monday and will let u know how it goes.... but till then try searchin the boards; ppl have had positive results
deyainrdy4ds is offline   Reply With Quote
Old 04-12-2008, 01:58 PM   #3 (permalink)
~BANNED~
linh's Avatar
Vehicle: 06' CLK 500 Cabrio, 01' CL 55, 01' CLK 430, 04' Civic
Don't go with KMAC kit. It expensive and it will cost even more to push out the old bushing and press on the new adjustable bushing. There's a better camber kit link for the rear that you can install yourself with just 2 bolts. It can be easy put back to stock. Call leonard at 619-886-4678 or leonard.carson@gmail.com
linh is offline   Reply With Quote
Old 04-12-2008, 02:10 PM   #4 (permalink)
Vehicle: w208
Originally Posted by linh View Post
Don't go with KMAC kit. It expensive and it will cost even more to push out the old busing and press on the new adjustable bushing. There's a better camber kit link for the rear that you can install yourself with just 2 bolts. It can be easy put back to stock. Call leonard at 619-886-4678 or leonard.carson@gmail.com
sht...wish i knew about this b4 i bought the kit lol...ah well
Old 04-12-2008, 09:09 PM   #5 (permalink)
~BANNED~
linh's Avatar
...........always ask first before you decide to do any mods. It can save you $$$$, times and labors.
Old 04-12-2008, 09:27 PM   #6 (permalink)
Vehicle: w208
i did plenty of times before n did my research on the camber kits on here! it was just when u decided to disappear from the forums! lol
Old 04-12-2008, 09:39 PM   #7 (permalink)
rlwatson's Avatar
Date registered: Oct 2005
Vehicle: 2002 CLK430 Cabriolet
Send a message via AIM to rlwatson
Hey Deyainrdy4ds, What are you using on the front? Is a camber kit not required for the front?
'02 CLK430 Cabriolet (Brilliant Silver)
Color matched sport grill with Chrome Star
Flat hood badge/emblem
Projector Headlights with Halos
Clear side marker lights w/chrome bulbs
Command/Nav.
Voice Activation
v60 Bluetooth Puck w/K1m Phone by Motorola®
Dual K&N Air Filters
19" Replica AMG Dual-Spoke Wheels (Bright Silver); (F-8.5, R-9.5) with Goodyear F1 GS-D3 Tires (F-235/35, R-265/30)
4-pc Chrome AMG Pedal Set
Brembo Sport Drilled Rotors w/Akebono Euro Pads
G-Stop Stainless Steel Brake Lines
rlwatson is offline   Reply With Quote
Old 04-12-2008, 09:47 PM   #8 (permalink)
Vehicle: w208
yeah ,..i got front and rear KMAC camber kits....my front needs it a lot more
Old 04-12-2008, 10:00 PM   #9 (permalink)
rlwatson's Avatar
What about the front? Does leonard have something for that, or is KMAC the way to go on the front.
Old 04-13-2008, 12:53 PM   #10 (permalink)
~BANNED~
linh's Avatar
Leonard only make kit for the rear. The front are usually does not have camber problem when lower unless you drop your car like a lower ride. I've lower my Slk, Clk 430, CL 55 and Clk 500 Cabriolet and the tire wear on the front are all perfect. I never need the Mercedes alignment bolt. But if your front alignment are off, it best to go with Mercedes alignment bolt. The worse case, you have to go with Kmac kit if your car is lower like a low rider.
Rear camber kit.. childofjuly W124 E,CE,D,TD Class 1 12-11-2007 08:38 AM
Rear Camber Kit Bazzle R170 SLK Class 8 07-06-2007 08:07 PM
Rear Camber arms Bazzle R170 SLK Class 13 05-30-2007 10:40 PM
rear camber problem shlyd W126 S,SE,SEC,SEL,SD,SDL Class 4 12-29-2004 09:15 AM
rear camber hieubenz W208 CLK Class 3 02-04-2003 10:17 AM
