Old 04-19-2008, 10:16 PM   #21 (permalink)
bankerkys's Avatar
Date registered: Nov 2007
Vehicle: 2002 CLK430, 2007 FJ Cruiser TRD
RE:
I'd love to see a new supercharger kit hit the market. I recently spoke to STS about a turbo, and they told me tuning would run $15,000-$18,000. So total cost with the turbo would be about $30,000!
bankerkys is offline   Reply With Quote
Old 04-20-2008, 04:29 AM   #22 (permalink)
snakoiler's Avatar
Date registered: Feb 2005
Vehicle: 2002 430clk
you can get a kleeman for less than that and its proven power
Mod list:Carlssons front bumper, custom angel eye fogs, headlight rings, #1 pads, Eibach springs, Inmotion ECU tuning, chrome wheels, Illuminated door sills, in dash DVD with TV and backup camera, complete audio system, AMG pedals, LED lights, Blk maple and chrome shift knob, blk maple center cover and door pulls, Zaino, H&R 10mm spacers, K&N filters, Magnaflow exhaust
snakoiler is offline   Reply With Quote
Old 04-21-2008, 01:08 PM   #23 (permalink)
SMP
Date registered: Feb 2008
WOW!
yeah i use a piggy back system called "Perfect Power" out of South Africa...Welcome to Perfect Power - Complete Engine Management and Fuel Injection Systems including Stand-alone and Piggy-back Systems and then use the ecm SMT6 for tuning...all i need is the TPS sensor, MAF sensor and tap in to a vacuum line and add a 2 bar map sensor and ECT Sensor and i can pretty much tune that way for fuel and timing is a bit more complicated but i believe anything that has a 5 volt reference i can work with is needed
if it will work on a damn Saturn ION it should work on a Benz!
SMP is offline   Reply With Quote
Old 04-22-2008, 09:39 AM   #24 (permalink)
Date registered: Jan 2007
Vehicle: CLK 430
No matter what, any FI done to the car is going to be pricey, even if you're loaded, it's not like 20k give or take is chump change.
BENSIN is offline   Reply With Quote
Old 04-22-2008, 11:02 AM   #25 (permalink)
SMP
NOOOOO at the most 5-6K AT THE MOST!
Old 04-22-2008, 08:11 PM   #26 (permalink)
PixsouL's Avatar
Date registered: Jul 2004
Vehicle: CLK430
Send a message via AIM to PixsouL Send a message via Yahoo to PixsouL
Yeah, I talked to STS too and they stopped talking to me for some reason. Even one of their "Preferred Shops". I think they just don't want to deal with a Benz or something. Very unprofessional. Really good at making you think its cheap and easy, but when it comes down to it there is only a few options for us.
So.... Any one have any luck getting a hold of House of Power? I have tried many times with no success.
Thanks,
Dave Schlaegel
PixsouL is offline   Reply With Quote
Old 04-24-2008, 02:18 AM   #27 (permalink)
Williams707's Avatar
Date registered: Jul 2006
Vehicle: 2000 CLK 320
Seems the compression ration is the same for the CLK 320 / CLK 430. With that being said is it possible to run the same SuperCharger or is there other things to consider?
I'm also wondering if the same mounting bracket for the supercharger will work?
2000 CLK-Class CLK320
• 3,199 cc 3.2 liters 6 V front engine with 89.9 mm bore, 84 mm stroke, 10 compression ratio, overhead cam and three valves per cylinder
• Power: SAE and 160 kW, 215 HP @ 5,700 rpm; 229 ft lb, 310 Nm @ 3,000 rpm
• Coefficient of drag: 0.31
• Weights: curb weight (kg) 1,470
2000 CLK-Class CLK430 Coupe
• 4,266 cc 4.3 liters 8 V front engine with 89.9 mm bore, 84 mm stroke, 10 compression ratio, overhead cam and three valves per cylinder
• Power: SAE and 205 kW, 275 HP @ 5,750 rpm; 295 ft lb, 400 Nm @ 3,000 rpm
• Weights: curb weight (kg) 1,526
The CLK55 has a compression ratio of 10.5:1
Anyone know about these systems?
Mosselman Turbo
H&R Cup Kit, Front #4 pad and Rear #1 pad
Sports Grill, Silver with Chrome Trim
Pirelli P-Zero Nero 225/30/20
Pirelli P-Zero Nero 255/30/20
Weds Kranze Bazreia Front ET38 8.5j
Weds Kranze Bazreia Rear ET32 10j
Super Sprint Muffler with Oval Tip
Super Sprint Resonator
HID H3 6000K Fog lights (HID Kit)
HID D2R 6000K Projector Head Lights (OEM HIDs)
LED Tail Lamps
LED (Blue) Interior Lights including the Door, Glove Compartment, and Trunk
LED (White) Vanity Mirror and License Plate Lights
Williams707 is offline   Reply With Quote
Old 04-25-2008, 11:36 PM   #28 (permalink)
bankerkys's Avatar
I have tried contacting HoP as well - they have never responded.
Old 04-25-2008, 11:38 PM   #29 (permalink)
bankerkys's Avatar
I just sent an e-mail to a distributor in South Florida about Mosselman. They have a kit listed on their website for $6500.00. The power increase, however, is only about 80hp. If I can get in touch with them, then I will post the information here.
Website: direct sales and design (all one word) dot com.
Old 04-27-2008, 03:11 AM   #30 (permalink)
PixsouL's Avatar
Vehicle: CLK430
bankerkys let me know if you get any info from them about the Mosselman one. I couldn't see a kit for the CLK430, only 320 for some reason. Man, both them and Mosselman have horrible websites.
Maybe time for a 150Shot of Nitrous, haha.
Looking for a GOOD Supercharger for a CLK 430 James Tubo General Mercedes-Benz 1 10-13-2006 12:27 PM
1999 CLK 430 kofax General Mercedes-Benz 3 02-27-2006 06:41 AM
1999 CLK 430 kofax W208 CLK Class 8 02-26-2006 08:32 PM
1999 CLK 430 kofax The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 02-26-2006 11:25 AM
FS: Modded 1999 CLK 430 str8ridin For Sale, Trade & Wanted Items 7 07-19-2005 03:07 PM
