Old 03-06-2008, 08:45 AM   #1 (permalink)
Date registered: Oct 2005
Vehicle: 99 CLK 320
Send a message via Yahoo to omega1_95
heavy vibration
My clk vibrates when in drive and i come to a complete stop. I have had the plugs replaced ( the wires are fine), the egr valve has been replaced also. Dealer is saying I need new motor mounts. Has anyone had similar problems. Any help would be appreciated.
omega1_95 is offline   Reply With Quote
Old 03-06-2008, 09:11 AM   #2 (permalink)
chromejunkie's Avatar
Date registered: Dec 2007
Vehicle: bike cost too much to drive
check motor mounts and trans mounts . the rubber goes bad and cracks causing a vibration and a stop or idle . hope that helps
aww screw ups ship fed ex keep me busy
chromejunkie is offline   Reply With Quote
Old 03-06-2008, 11:54 AM   #3 (permalink)
Rashman's Avatar
Date registered: Nov 2007
Vehicle: '01 Avantgarde CLK 230 Kompressor
I agree.
My dad's older E-Class was recently vibrating in reverse gear but not drive gears. Symptoms of worn engine mounts. Once they were changed, all was well.
Rashman.
____________________
19" replica Carlsson 1/16 rims
Eibach ProKit
Koni adjustable sport dampers
20mm SCC Hubcentric Spacers
Blue LED interior lighting
Green Induction Kit
SuperSprint backbox
Front camber adjust
#2 front spring pads
Flat Bonnet badge
Side trim Kompressor badging
Blue Calipers, Hubs & Disc Guards
Rashman is offline   Reply With Quote
Old 03-07-2008, 03:18 AM   #4 (permalink)
99CLKcab's Avatar
Date registered: Mar 2006
Vehicle: 1999 CLK 320 cabriolet
Send a message via AIM to 99CLKcab
Had it happen to me, I kinda tore them... whoops! I got everything done for like $250 with labor. It was a pretty good deal.
Yosey Drinks TAB? And likes it?
99CLKcab is offline   Reply With Quote
Old 03-07-2008, 10:48 AM   #5 (permalink)
Date registered: Nov 2006
Agree on motormounts/tranny mount.
I had mine replaced about 6 months ago. Drives like new.
semiretired is offline   Reply With Quote
OT too heavy ThrillKill Off-Topic 2 01-30-2007 09:23 AM
Reverse very heavy ProvingGrounds W140 S-Class 14 11-03-2006 09:21 AM
Need Help!!!! .. Heavy Vibration..... dennisB W126 S,SE,SEC,SEL,SD,SDL Class 9 12-25-2005 11:54 PM
300sd too heavy spanish300sd W126 S,SE,SEC,SEL,SD,SDL Class 8 07-08-2005 10:09 PM
heavy vibration 5-20 mph 280 GE toka G-Class 7 01-12-2004 07:53 AM
