Old 03-04-2008, 12:39 PM   #1 (permalink)
Date registered: May 2004
Need help replacing vacuum hose
I have a 2001 CLK 430, the other day, I replaced the CPS (crankshaft position sensor) and accidently broke the plastic connector to the vacuum hose from my intake to the brake booster. I have to get a brand new hose at the dealership. My question is how do you removed the side where it is connector to the brake booster. Is there screw in the back? Do I have to removed the brake booster to get the hose out for replacement? or can I just pull it out? Can anyone help? Thanks in advance.
bjorkson is offline   Reply With Quote
Vacuum Hose? torkq W123 E,CE,D,CD,TD,TE Class 13 01-18-2008 09:58 PM
Where does this vacuum hose go mbenzfan79 R/C107 SL/SLC Class 2 10-23-2007 07:59 AM
vacuum hose g_rivero W140 S-Class 1 09-04-2007 03:07 PM
Vacuum Hose Maybe? Htown W126 S,SE,SEC,SEL,SD,SDL Class 10 08-25-2007 06:37 AM
vacuum hose andreifs W124 E,CE,D,TD Class 0 02-13-2006 07:36 PM
