I noticed today when I'm on the highway I can feel a vibration throughout my car. I listened to see if I could find a source, but couldn't really hear anything. I'm pretty sure it's not coming from the engine but I'm not sure what else it could be. Anyone else have this problem?
"..I have seen the others and I have discovered that this fight is not worth fighting.."
Hello man..
Dont worry its not something serious..
Check the following :
1- Tires Direction and air pressure.. it may cause vibration on high speed.
2- Check the wheel balance.. ( i think this is the problem ) ..
If you have recently had your wheels off for whatever reason, make sure you put the wheels on the corners of the car that they came from.
Your front tyres will wear more quickly than the rears and will effect the handling.
I had this exact thing happen to me - the wheels on one side of my car were back to front.. Once I swapped the wheels to where they were before the ride was smooth again!!
Rashman.
____________________ 19" replica Carlsson 1/16 rims Eibach ProKit Koni adjustable sport dampers 20mm SCC Hubcentric Spacers Blue LED interior lighting Green Induction Kit SuperSprint backbox Front camber adjust #2 front spring pads Flat Bonnet badge Side trim Kompressor badging Blue Calipers, Hubs & Disc Guards
Haha I did that on my old car once. My CLK has staggered wheels though so I'm thinking it must be a pressure issue or mounting. Hopefully I can get around to checking it tonight after work, it didn't shake much at all on the highway today though.
