Old 03-02-2008, 10:47 AM   #1 (permalink)
Date registered: Feb 2008
Clk 200k Fault codes, need help
Hi Guys,
Hope you can help me, My car really sluggish and not driving like it used to.
I got thes fault codes: -
p0101 - mass or volume air flow circuit range/performance
p0130 - o2 sensor ciruit
p0131 - o2 sensor circuit low voltage
p0132 - o2 sensor circuit high voltage
p0171 - system to lean
p0410 - secondry air injector system fault
p0444 - evaporative emmission system purge valve circuit open
can any one suggest what i should do?
car is a 2001 200k CLK w208.
Thanks chaps
sciroccotune is offline   Reply With Quote
Old 03-03-2008, 08:49 AM   #2 (permalink)
Originally Posted by sciroccotune View Post
Hi Guys,
Thanks chaps
I think that it may be down to the o2 sensor as when cheking the fuel system it does not go into closed loop mode due to what it reports as a o2 sensor fault.
Problem is im not sure which o2 sensor it will be? I would think the first one pre cat?
Thanks guys
Old 03-03-2008, 04:31 PM   #3 (permalink)
well the light came back on and this time it has not had any effect on the way the car drives - it back to normal at the moment.
The code is p0101 - mass or volume air flow circuit range/performance but as said has no effect on the way the car drives, i guess that this means that the main cause of the problem is the 02 sensor. I will try and get a new one tomorrow and replace the pre cat one as i think that it would cause the problem although its hard to say from the codes - but seem to be indicated on various websites.
anyone got any ideas?
thanks agian
thanks agian
Fault Codes scabba W124 E,CE,D,TD Class 6 04-30-2007 01:22 PM
What Are These Fault Codes??? Dolphin27 R170 SLK Class 11 03-05-2007 06:15 AM
Help with fault codes please. basix W201 190E, D-Class 2 12-25-2006 04:40 PM
Fault Codes aqorps W124 E,CE,D,TD Class 12 08-18-2006 11:27 AM
Fault Codes YOGGI W202 C-Class 1 07-17-2006 07:21 AM
