Old 03-01-2008, 01:31 PM   #1 (permalink)
RK430's Avatar
Date registered: Feb 2008
Vehicle: 2000 CLK 430
where to put the jack stand?
I'm trying to lift my CLK up to change oil and the trans fluid. I use my floor jack and lift it where the factory hand jack goes. Once I lift one side up, I don't see any 'frame' part where I can place the jack stand. On most cars, you can see the subframe and place the jack stand there. Too many plastic cover under the car.
Can anyone tell me how?
Thanks,
RK430
2000 CLK430
RK430 is offline   Reply With Quote
Old 03-01-2008, 04:14 PM   #2 (permalink)
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: CLK430
I've used the lower a-arm to suspend the front. This isn't the best angle, but hopefully it will help. Once I have it on the stands, I shake the car before taking the wheels completely off. This ensures it's not going to fall down on it's own.
Lastly, using a vacuum pump makes oil changes much easier.
MarcusF is offline   Reply With Quote
Old 03-01-2008, 09:08 PM   #3 (permalink)
RK430's Avatar
Thanks MarcusF. After I removed the plastic cover under the car, I used the frame/crossbar where the a-arms are mounted on. If I lift the front high enough, I can put a jackstand on the rear near the factory hand jack lift points.
I completed changing the engine oil and the trans fluids. The jobs are easy after I read the DIYs here. This forum is great. Thanks you all.
Jack Stand Placement varlerw2 R129 SL Class 2 10-27-2007 04:02 PM
Opinions - Jack Stand location Texas General Mercedes-Benz 2 10-13-2006 07:10 PM
Rear Jack stand location Michael Pillay W126 S,SE,SEC,SEL,SD,SDL Class 9 08-04-2006 03:14 AM
Jack and Jack stand recomendations Steve230 R170 SLK Class 16 07-06-2004 10:39 AM
What weight rating of jack and stand should be used for ML? noelb W163 M-Class 14 04-11-2002 10:52 PM
