Old 02-29-2008, 12:30 PM   #1 (permalink)
RK430's Avatar
Date registered: Feb 2008
Vehicle: 2000 CLK 430
recommended engine oil
Hi,
I know the engine oil topic has been covered 10k times. Let me ask it one last time.Can I mix 6 qt Mobil1 0w-40 and 2 qt Mobil1 10w-30?
The reason is I already bought 6 qt of Mobil1 10w-30 thinking this should be okay for my car since 10w-30 is so commonly used in many cars. Then I read more and more about oil in this forum and found Mobil1 10w-30 is NOT MB approved and only 0w-40 is. Is that true?
Since I already bought the 10w-30, I was wonder can I mix them so I don't have to waste those 6 qt of 10w-30.
Thanks,
RK430
2000 CLK430
RK430 is offline   Reply With Quote
Old 02-29-2008, 01:57 PM   #2 (permalink)
Date registered: Mar 2006
Vehicle: 2000 CLK430 Silver/Grey
Send a message via AIM to chem1441 Send a message via Yahoo to chem1441
I wouldnt mix weights. I dont think 10W-30 is going to hurt anything. If I were you I would either buy 2 more quarts of 10W-30, and use the "right" weight next time, or just bite the bullet and go buy 8 quarts of 0W-40.
chem1441 is online now   Reply With Quote
Old 02-29-2008, 03:49 PM   #3 (permalink)
Date registered: Aug 2006
Vehicle: 01 CLK430 Cab
Don't mix your oil, it's not good for your engine. You could try bringing them to an auto parts store and ask if you can just exchange them for the correct weight and tell them you lost your receipt.
SilverBillet is offline   Reply With Quote
Old 02-29-2008, 05:01 PM   #4 (permalink)
rlwatson's Avatar
Date registered: Oct 2005
Vehicle: 2002 CLK430 Cabriolet
Send a message via AIM to rlwatson
Yeah, Wal-Mart will most likely give you a store credit. Then you can purchase the correct weight.
'02 CLK430 Cabriolet (Brilliant Silver)
Color matched sport grill with Chrome Star
Flat hood badge/emblem
Projector Headlights with Halos
Clear side marker lights w/chrome bulbs
Command/Nav.
Voice Activation
v60 Bluetooth Puck w/K1m Phone by Motorola®
Dual K&N Air Filters
19" Replica AMG Dual-Spoke Wheels (Bright Silver); (F-8.5, R-9.5) with Goodyear F1 GS-D3 Tires (F-235/35, R-265/30)
4-pc Chrome AMG Pedal Set
Brembo Sport Drilled Rotors w/Akebono Euro Pads
G-Stop Stainless Steel Brake Lines
rlwatson is offline   Reply With Quote
Recommended Oil eclark R/C107 SL/SLC Class 8 01-09-2007 01:25 PM
what oil is recommended for 300sd cornpone W126 S,SE,SEC,SEL,SD,SDL Class 6 12-17-2006 10:12 AM
Recommended Oil paddyb W202 C-Class 4 01-26-2006 10:21 AM
Recommended oil grades Ernest T Bass G-Class 4 06-22-2005 03:32 PM
Which type of engine oil is recommended by MB ? les paul General Mercedes-Benz 4 01-24-2004 01:51 PM
