Old 02-19-2008, 10:17 PM   #1 (permalink)
babyboigsxr's Avatar
Date registered: Feb 2008
Send a message via AIM to babyboigsxr
Exclamation Important Question about my NEWLY PURCHASED CLK 320 (W208), I need to know right away
Okay, here's the deal. I recently "bought" my CLK last week, and i barely made the last cash payment today. So in other words, today was the day when i was able to take the car home. and now i have a huge important issue/question.
The day i made a down payment to the private seller, i test drove the car. it's excellent. but today, on the way home on the freeway, WHEN I FLOORED IT, it didn't pick up quick.
AND...
when i was at a red light, as soon as it turned green, i pressed the gas pedal all the way, and it LITERALLY took 4 seconds til the car even moved forward.
WHY IS THAT?!?!?!?
oh, by the way, is there some type of "rev limitor" or "speed limitor" on the car?
My car is a 2001 CLK 320. PLEASE... PLEASE... LET ME KNOW. thanks.
THIS IS THE VERY FIRST BENZ I EVER OWNED.
babyboigsxr is offline   Reply With Quote
Old 02-19-2008, 10:22 PM   #2 (permalink)
Date registered: Aug 2006
Vehicle: 01 CLK430 Cab
Look to the left of the shifter, there is a button that has W and S on it. Make sure its on S and not on W. W=winter and S=summer. When you have it on W, the transmission is starting out on the second gear to prevent slippage.
If that didn't work, your MAF is probably dirty or need to be replace. Don't panic, its a common problem on our cars. Good Luck and keep us posted.
SilverBillet is offline   Reply With Quote
Old 02-20-2008, 01:04 AM   #3 (permalink)
Talking
Okay, well, when i drive the car tomorrow, i'll switch it to "S" instead of "W", cause the previous owner kept it on "W".
other than that, what's "MAF"? sorry bro, i'll get use to these terms soon. but for now, i need everyone to guide me through simple things. LoL.
Old 02-20-2008, 03:42 AM   #4 (permalink)
DENNIStheMENACE's Avatar
Vehicle: CLK320
MAF is a mass air sensor that measures density of the intake air so that the appropriate amount of gas can be mixed for combustion.
http://www.benzworld.org/forums/atta...eaning-maf.pdf
CLK320
DENNIStheMENACE is offline   Reply With Quote
Old 02-20-2008, 03:56 AM   #5 (permalink)
unlukky's Avatar
Vehicle: 2001 CLK55 AMG (1 of 1,313 in U.S.)
Post
I agree with the idea of the MAF being a culprit. But try this too...
The quick way to reset the transmission and throttle body communications (which is where a lot of shifting weirdness lies) is to do the following step by step:
1. Get in and shut the door
2. Turn key to position 2 (right before the start position) DO NOT START THE CAR
3. Press the gas pedal to the floor... past the kick down point... see why I say DO NOT START THE CAR!??!
4. Hold the pedal there for 15 seconds
5. After 15 seconds while foot still planted, turn the key off but do not remove it
6. Release gas pedal... and get ready to be bored
7. Wait at least 2 minutes while not touching anything in the car, don't open the door even.
8. After the 2 minutes start the car and drive off normally... you should notice a difference in the shift pattern and smoothness.
--John
2001 CLK55 AMG
18" Mandrus Millenium wheels
Resonator Delete
Green Filters
H&R Sport Springs and 1 bump cups on all 4 corners
unlukky is offline   Reply With Quote
Old 02-20-2008, 10:38 AM   #6 (permalink)
Talking
Cool. Thanks for the info man. Very much appreciated.
Old 02-20-2008, 10:40 AM   #7 (permalink)
Talking
Just a quick question, once i follow those steps, what's going to be different? Or in other words, what does that do? (detailed-wise). is it just for a smoother shift? or will it pick up a lot faster than normal?
let me know. thanks.
Old 02-20-2008, 11:20 AM   #8 (permalink)
Rashman's Avatar
Date registered: Nov 2007
Vehicle: '01 Avantgarde CLK 230 Kompressor
Hi mate.
Yes, I too have heard of this process.
However, the instructions I was given were not as thorough as yours so I will give it another go and see how I get on. I was also told only to hold the gas down for 5 seconds.
Is there any risk of flooding the engine with fuel by holding down the throttle for 15 seconds?
Respect to the 55, by the way.
Thanks in advance.
Rashman.
____________________
19" replica Carlsson 1/16 rims
Eibach ProKit
Koni adjustable sport dampers
20mm SCC Hubcentric Spacers
Blue LED interior lighting
Green Induction Kit
SuperSprint backbox
Front camber adjust
#2 front spring pads
Flat Bonnet badge
Side trim Kompressor badging
Blue Calipers, Hubs & Disc Guards
Rashman is offline   Reply With Quote
Old 02-20-2008, 11:46 AM   #9 (permalink)
Mr. Pie's Avatar
Date registered: Nov 2004
Vehicle: CLK320 / E500
Send a message via MSN to Mr. Pie
Our cars are adaptive, meaning it learns your driving style. So your car is probably remembering how the other driver drove the car. The reset puts it back to factory which means it will need to re-learn how you drive. So it may be a little more punchy at the start.
2001 W208 Black Opal Metallic
K2a, K3, K4 + COMAND, HID halo projector headlights, flat hood emblem, chrome cluster rings, Bluetooth phone adapter, MB illuminated door sills, AMG steering wheel, AMG pedals, chrome AMG II dual spoke wheels, Nitto NT 555 Extreme Performance, 235/35/19 front, 265/30/19 rear
2004 W211 Platinum Blue Metallic
Premium Package, Apperance Package, Keyless Go, Bluetooth puck and tail
Mr. Pie is offline   Reply With Quote
Old 02-20-2008, 11:58 AM   #10 (permalink)
biggnolo's Avatar
Date registered: Jan 2008
Vehicle: mercedes clk 320
Send a message via AIM to biggnolo
Post same problem
i had that same problem when i got mine 3 weeks ago. then my friend gets in and says that i should have it on S so it can take off quicker..and low and behold he works didnt no what it was for in the begining
biggnolo is offline   Reply With Quote
FS: W208 CLK 320 stock springs clkase For Sale, Trade & Wanted Items 0 08-29-2007 09:56 PM
Free: W208 CLK 320 Resonator HRECLK Freebies! 1 02-24-2007 12:44 PM
New to CLK. Just purchased '98 CLK 320. Question... Merc250c W208 CLK Class 5 05-25-2006 01:42 PM
Tire problem on newly purchased Starmark ML jwalther W163 M-Class 7 08-12-2004 05:44 AM
newly purchased 2004 S430 - CHARCOAL INTERIOR YGOHOME W220 S-Class 10 05-17-2004 08:42 AM
