I have a heavy vibration when i come to a stop. I have changed the plugs, replaced egr valve which was cracked and cleared all codes. Car does not vibrate when in reverse or neutral only when in drive. Anyone have any ideas??
Not too expensive. Bit of labour though. It can be done by lifting the engine using a trolley jack and then putting new mounts into place.
Know what you're doing if you're going to do it. I had my "doctor" do it.
Rashman.
____________________ 19" replica Carlsson 1/16 rims Eibach ProKit Koni adjustable sport dampers 20mm SCC Hubcentric Spacers Blue LED interior lighting Green Induction Kit SuperSprint backbox Front camber adjust #2 front spring pads Flat Bonnet badge Side trim Kompressor badging Blue Calipers, Hubs & Disc Guards
