Old 01-20-2008, 05:34 PM   #1 (permalink)
bigtis's Avatar
Date registered: Jun 2007
Vehicle: clk 430
2001 tranmission trouble
my friends 01clk320 will not go in to drive
it takes a while to do so
so i was wondering how much u guys think a rebuild of the trans will cost
or do you guy and gals know of a site that sells our trannys
thanks
bigtis is offline   Reply With Quote
Old 01-20-2008, 09:21 PM   #2 (permalink)
Jays_Z's Avatar
Date registered: Jan 2007
Vehicle: 2001 clk430
Before you do that change the oil and filter in the transmission first. I had the same problem and thought i need a new tranny till i changed the fluids. Runs like a brand new machine. Cost me around 150 at a local MB indy shop.
My brooklyn charm gets them everytime.
Jays_Z is offline   Reply With Quote
Old 01-21-2008, 09:36 AM   #3 (permalink)
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: CLK430
At this point, your friend doesn't "know" that they need a new trasmission, but Sun Valley New Mercedes Parts sells rebuilt 722.6 transmissions for $2750. They can be reached at 818 768 8667.
MarcusF is offline   Reply With Quote
Old 01-21-2008, 05:12 PM   #4 (permalink)
bigtis's Avatar
Vehicle: clk 430
THANKS GUYS WEE WILL TRY THESE THEN I POST IF IT WORKED OR NOT
Old 01-21-2008, 05:52 PM   #5 (permalink)
bigtis's Avatar
Vehicle: clk 430
Question
OH YEAH I FOR GOT TO SAY THAT WHEN WE PUT IT IN DRIVE AND TRY 2 USE THE
IT DOES NOT CHANGE THE [D] ON THE PANEL LIKE IT USED 2 DO
SO WHAT DO U THINK OF THAT?
Old 01-21-2008, 06:03 PM   #6 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Has he spilled anything in the center console lately?
Meister Eckhart
Old 01-22-2008, 06:27 AM   #7 (permalink)
bigtis's Avatar
Vehicle: clk 430
Post
no he has not spilled any thing
we hear a grinding noise we he trys 2 pull off in drive
also is there a diy transmission fluid change on the w208
any link will be helpful thanks
Old 08-26-2008, 10:03 PM   #8 (permalink)
Date registered: Jul 2008
Vehicle: 2009 Mercedes CLK430 Convertible
Sorry to jump in on this thread but I am having a similar problem. Gregs210, I did spill liquid into the center console. What did I fry and can I fix it? I have a 2001 CLK430. Bigtis, sorry to fragment your thread.
allen939 is offline   Reply With Quote
Old 08-26-2008, 11:19 PM   #9 (permalink)
gregs210's Avatar
Hi, Allen. Welcome aboard, please click the user cp link and update your profile for vehicle and location as that is useful information.
You've discovered one of the serious design flaws in the later model MBs. The Transmission Control Module (the brain for the transmission) is unsealed and under the center console. Liquids wreak havoc; if you only spilled a lighter liquid like water, you may be able to save the part by disassembly and drying it out, if not the part alone is several hundred bucks. At any rate, here is the link to a good DIY on it:
http://www.benzworld.org/forums/w208...e-removal.html
Disconnect the battery before you start, and that will reset things while you're working. Remove it, dry it out thoroughly (blow it dry with canned air), then leave it out overnight. If you spilled something other than water, go to Radio Shack and pick up a can of electrical contact cleaner and hose it down good, then let stand overnight. After it's all reconnected you can leave the console partially disassembled, then reconnect the battery and start it up, do the reset dance and then go for a quick drive. If that resolves it, you can make the console all pretty again, say a quick prayer of thanksgiving and send me a Starbucks gift card.
Seriously, I hope drying it out resolves the issue.
Take care and enjoy the ride,
Greg
Old 08-27-2008, 06:41 AM   #10 (permalink)
gregs210, Thanks! One other small question...when I disconnect the battery, will anything lock when I reconnect it that I will need passcodes for (i.e nav system, radio, etc...)?
help for tranmission of w123 harpreet928 W123 E,CE,D,CD,TD,TE Class 6 09-23-2007 01:33 PM
Tranmission Oil kyericho R129 SL Class 4 10-19-2006 01:43 PM
2001 E55, more brake trouble timstiles W210 E50 AMG, E55 AMG 2 08-25-2006 06:14 PM
info help on tranmission? slvr430ml W163 M-Class 1 09-12-2004 09:04 AM
phone trouble c320/2001 shuttertwo General Mercedes-Benz 1 08-06-2004 03:57 PM
