Old 01-20-2008, 12:48 AM   #1 (permalink)
Date registered: Dec 2007
CLK320 Spring Pads?
I want to know what # spring pad the 99' CLK320 uses factory wise. Front and rear ?
J_STATUS is offline   Reply With Quote
Old 01-20-2008, 02:41 PM   #2 (permalink)
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: CLK430
I thought Mercedes-Benz installed spring pads based on the equipment level of the particular car being built. If you're trying to determine which spring pads your car currently has installed, you can reach into the wheel well and feel the number of bumps on the pads.
MarcusF is offline   Reply With Quote
Old 01-22-2008, 02:22 PM   #3 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
That was my understanding as well, it's based on equipment, engine, etc and final ride height. I've heard people express rather sweeping opinions about what pads MB "always" puts in, but I've heard nothing definitive about that.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 01-22-2008, 08:09 PM   #4 (permalink)
lz_clk's Avatar
Date registered: Mar 2004
Vehicle: 1999 CLK 320
Send a message via MSN to lz_clk Send a message via Yahoo to lz_clk
I can tell you that I have a 99 CLK 320 and still have my original rear spring pads on and had to replace my front ones with #2's after I dropped it because the drop was not noticeable at all in the front. Hope that helps somehow.
99 CLK 320 Quartz Blue
19" Brabus MB VI knock-offs, H&R springs, CLK sides, AMG rear, Lorinser front
lz_clk is offline   Reply With Quote
Old 01-23-2008, 03:31 AM   #5 (permalink)
A1EK's Avatar
Date registered: Sep 2005
Vehicle: W208 CLK230 Kompressor 2000 year, Brabus Monoblock VI, 15mm spacers, Eibach Pro Kit, Flat emblem
Did you replace the pads yourself. or take it to a garage? I have replaced the coils myslef, but without the coil compressor that works from the inside of the coil through the hole in the bottom of the wishbone it was very tight to remove.
A1EK is offline   Reply With Quote
CLK320 Pads? macclk W208 CLK Class 3 06-02-2007 05:56 PM
Spring pad for CLK320. 00CLK208 W208 CLK Class 1 04-03-2007 01:07 PM
Pls. Post Pics of your Lowered E and mention Tire size, Spring Pads size,Spring used. spine911 W210 E-Class 3 11-17-2004 06:03 PM
Rage2, what spring pads did you use with your Eibach spring? Hadir R170 SLK Class 3 04-13-2002 07:05 PM
Linh, do you know how to change spring pads without a spring compressor? SteveL R170 SLK Class 7 04-05-2002 02:34 PM
