Old 01-19-2008, 10:51 AM   #1 (permalink)
Date registered: Dec 2007
Vehicle: CLK 430 Cabriolet
ESP Switch
When I turn mine off the yellow warning light comes on to indicate it has been turned off. When I'm at a stand still and slam on the gas the light blinks like it trying to compensate for wheel spin. Does that sound right? I thought when you turned it off the computer wouldn't compensate.
bigpimp is offline   Reply With Quote
Old 01-19-2008, 04:44 PM   #2 (permalink)
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: CLK430
According to MB, with ESP on, when the ECU determines there is wheel slip on a rear wheel (there are speed sensors at each wheel), the ECU will dial back power using the electronic throttle and apply brakes to the single that is slipping.
With the ESP off, the ECU will not impede the electronic throttle, however, it will still apply brakes to the drive wheel that's slipping.
MarcusF is offline   Reply With Quote
How to switch off ESP, ABS & BAS systems JG01 W203 C-Class 10 10-18-2008 10:27 PM
How to temporarily disable ESP (without using switch) SLacKer-320 R170 SLK Class 9 09-16-2007 05:36 AM
brake switch seems fine, but ESP/ABS light is on skipinschool W210 E-Class 8 07-16-2007 07:13 PM
ESP switch raychan General Mercedes-Benz 4 03-16-2006 10:09 PM
Thought I'd found a way to switch off the ESP "nanny " light... Marty, England R170 SLK Class 2 07-27-2001 11:05 AM
