Old 12-28-2007, 09:17 AM   #1 (permalink)
spoons's Avatar
Date registered: Mar 2006
Vehicle: 2006 C230 Sedan
Send a message via Yahoo to spoons
Thumbs up DIY Oil Change for a CLK
Attached is a PDF that will show you step by step how to perform your own oil change. The PDF file shows a CLK430, but the same procedure works for CLK320, CLK350 & CLK55 only the amount of oil maybe different. Check owners manual for Oil Capacity.
Brian Richardson
Jupiter, FL
2006 Mercedes Benz C230 with 6-speed manual
1997 Plymouth Prowler with Matching Trailer
2003 Mercedes Benz C230 Kompressor (Sold)
1993 Mitsubishi 3000GT VR-4 (sold)
spoons is offline   Reply With Quote
Old 12-29-2007, 06:49 PM   #2 (permalink)
Date registered: Sep 2006
Fantastic Write-up!
EXCELLENT post! Thanks a million!
dachoklit1 is offline   Reply With Quote
Old 01-03-2008, 02:15 PM   #3 (permalink)
Date registered: Oct 2006
I've search all over this forum and this is the best DIY for oil change instructions ever!!!Thanks for posting a MB DIY OIL CHANGE GUIDE for Dummies.
2002 CLK 430. South Carolina. Pioneer Avic-Z1 Navigation Unit
kleenkut13 is offline   Reply With Quote
Old 01-03-2008, 05:00 PM   #4 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
You searched all over? And you don't like mine? My feelings are hurt...
This is for a W210 by the drain method, but it's the same V6 you guys have.
http://www.benzworld.org/forums/w210...ml#post2252050
A couple of tips for the DIY-newbies.
First, forget about the "oil input" on the other DIY. While you have the filter assembly out, pour the fresh oil down that huge hole. Less chance to spill, no funnel needed (and no funnel to clean up afterwards). (Obviously, if you drained the oil, be sure to put the drain plug back in first!!)
Second, once you have torqued your filter assembly back in, clean the edge of the housing and then use an awl (or even a nail, it's just aluminum and composite) to gently score a line perpendicular to the joint between the housing and the top of the assembly so that it scores both components. In the future, you don't need a torque wrench, so long as you fit a new o-ring each time when those two lines match up you'll be more than close enough for government work. Naturally, this is optional, some folks would not choose to do this.
Third, have two rags handy when you pull the filter assembly out. One you use to catch the assembly so as not to drip stuff all over, then the other -- this one should be clean and lint-free -- you use to ball up softly so it covers the opening on the engine. Lots of things can fall into gaping holes, and in this case none of them would be good.
Take care and enjoy the ride,
Greg
Old 05-23-2008, 01:09 AM   #5 (permalink)
koray's Avatar
Date registered: Jan 2008
Vehicle: 2000 S320
thank you very much... are there any secret hints about dash board?? can i see my speed on digital panel on 2000 w220 for instance
koray is offline   Reply With Quote
Old 05-23-2008, 06:30 PM   #6 (permalink)
sfclk's Avatar
Date registered: Mar 2008
Vehicle: 1999 CLK320
Send a message via AIM to sfclk
How much oil do you guys like the engine to run? Since my light came on, I'm going to start to fill the car up to 3/4 to the MAX on the dipstick.
3 days ago I got the "defective oil sensor" warning...car drove normally
2 days ago the "Check Engine" light lit up...drove normally
Last night I checked the oil, cleaned the dipstick o-ring and added oil.
This afternoon, they both went off by themselves after a few drives. I read that the CEL can turn itself off after a few drives, but what do you guys think the problem was?
sfclk is online now   Reply With Quote
Old 05-23-2008, 07:03 PM   #7 (permalink)
Date registered: Feb 2003
Vehicle: 2002 CLK55///04BMWxi
Here is another method.....suction from dip stick
MercedesShopWiki: OilFilter2
2002 Obsidian Black CLK55
Lorinser roof spoiler
AMG Illuminated door sills
command by steve
tomtomtomtom is offline   Reply With Quote
Old 05-24-2008, 06:27 AM   #8 (permalink)
Date registered: May 2005
Vehicle: 99CLK320
I have a Topsider and it doesn't work well at all. Maybe I'm impatient but it seems like it would take hours to drain. I start the engine and heat the oil a bit before I try to drain it. Any suggestions?
dlbehrns is offline   Reply With Quote
Old 05-24-2008, 07:00 AM   #9 (permalink)
spoons's Avatar
dlbehrns,
Do you have the oil filter removed or loose when you attempt to "suck" the oil out? If so that could be the problem. There is not a proper seal to create a vacuum. I usually loose the filter, let the oil drain back to the pan. Then I hand tighten the filter assembly
Let me know if that works for you next time?
Old 05-24-2008, 01:43 PM   #10 (permalink)
Vehicle: 99CLK320
I honestly don't remember if I had the filter off or not but that is a very good and logical possibility. There would be room for air to enter the crankcase around the suction hose but not much. Hope I remember next time I change the oil. Cheers!
DIY : Oil Change hangon W163 M-Class 44 09-19-2008 02:29 PM
Poll: mileage between oil change / brand of oil / DIY or dealer ?? Thanks! Rohf (Seattle) R170 SLK Class 27 08-05-2008 07:58 PM
DIY oil change Neb W202 C-Class 28 06-12-2008 05:18 PM
DIY Oil Change -- E420 TyBenzo W210 E-Class 23 03-17-2008 01:48 AM
DIY oil change question five0 W163 M-Class 5 08-14-2007 04:41 PM
