Old 12-21-2007, 09:40 PM   #1 (permalink)
Date registered: Apr 2007
Shift module removal
I am trying to find a previous link that showed how to remove and clean the transmission shift assembly under the center console. I cannot find it anywhere! If anyone can show a link or post pics I would greatly appreciate it.
jerrsnbrg is offline   Reply With Quote
Old 12-22-2007, 02:22 AM   #2 (permalink)
A1EK's Avatar
Date registered: Sep 2005
Vehicle: W208 CLK230 Kompressor 2000 year, Brabus Monoblock VI, 15mm spacers, Eibach Pro Kit, Flat emblem
To remove the gear shift is simple, all you need to do is twist the plastic bottom part of the shift anti-clockwise half a turn and it will move down, then you simply pull the gear shift up and off the shaft. The centre trim should just pull up as its only held in be clips.
A1EK is offline   Reply With Quote
Old 12-22-2007, 05:44 PM   #3 (permalink)
I can get the trim off but there were some pics on how to remove the actual shift module itself and take it apart to clean the sensors inside of it. I think you also have to remove the armrest console to remove the shifter.
Old 12-26-2007, 12:33 AM   #4 (permalink)
Date registered: Nov 2007
Vehicle: 2000 CLK 430
Last weeks problem
I just did this last week. Once you get the trim off around the shifter which all is just snapped in and remove the shift knob. Unplug the electrical connections for the windows, airbag light, ecs, etc there will be three allen key bolts around the base, one in the front and two in the rear under the plastic bar. There is a switch on the right side on the front right side that needs to be turned about a quarter turn and pulled out. On the front left side you need to unplug the harness for the shifter. Also on the underside of the shifter the transmission linkage needs to be disconnected by removing one clip on the shifter arm. Which can be done from inside the car if you can fit your hand down there. To gain clearance to remove the shifter I removed the two philips screws under the pad in the center console. Once they removed I was able to manipulate the shifter out of the console.
dietz_28 is offline   Reply With Quote
Old 12-27-2007, 08:02 AM   #5 (permalink)
thanks for the info!
Old 01-06-2008, 06:36 PM   #6 (permalink)
Date registered: Sep 2007
Vehicle: 2001 CLK430 Cabriolet
Unhappy Shift module removal - what now?
OK, so I have the big plastic unit containing what I presume to be the TCM in it out of the car and on my kitchen table. How in the world do you get it out of there for cleaning? Please see pictures of plastic unit top and bottom and the terrifying hole in my car.
axncatsma is offline   Reply With Quote
Old 01-06-2008, 07:13 PM   #7 (permalink)
Date registered: May 2005
Vehicle: 99CLK320
Dude, good job! Maybe it doesn't come out? Marcus would know.
dlbehrns is online now   Reply With Quote
Old 01-07-2008, 11:26 AM   #8 (permalink)
Never one to wait around, I took the plastic part to the dealer. They nearly died when I asked them the same question. They sell the entire shifter assembly as one unit. Who knew? I just sprayed contact cleaner on the board and all of the gazillion wires and contacts and put it back together. It starts, runs, and drives, so we'll see what happens in July.
Old 01-07-2008, 04:41 PM   #9 (permalink)
Vehicle: 99CLK320
That is TOTALLY AWESOME. This could save a lot of $ for a lot people.
Why July?
Old 01-07-2008, 06:30 PM   #10 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Originally Posted by dlbehrns View Post
Why July?
I'm guessing that's when one of two things happens: Either her extended warranty expires or that's when the car is paid off. After all, they seem to know those things, don't they?
Seriously, though, axncatsma, congratulations. That is great news indeed.
For the sake of posterity I added this thread to the W210 DIY sticky, very useful information indeed.
Take care and -- ENJOY THE RIDE!
Greg
Shift Knob Removal Help ! GODZILLA W140 S-Class 8 07-06-2008 09:27 PM
Shift boot removal 79Mercy W123 E,CE,D,CD,TD,TE Class 13 11-28-2007 10:02 PM
Electronic Shift Module Bora20 W210 E-Class 6 09-28-2006 02:08 PM
Shift Knob Removal??? whitejavaS500 W220 S-Class 8 03-23-2005 12:36 PM
shift knob removal PrinceGeorges W126 S,SE,SEC,SEL,SD,SDL Class 2 04-30-2003 07:05 AM
