Idler Pulley Bearing replacement - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 11-25-2007, 11:48 AM Thread Starter
tbsi430's Avatar
Date registered: Oct 2004
Vehicle: 2000 CLK 430 Cab
The bearing on the idler pulley (top pulley on passenger side) feel apart then causing the belt to tear up. I bought a new belt but obviously need to replace the bearing as well. I tried to remove the bolt in the front of the pulley that holds the bearing but cannot pull the bolt completely out since the back of the radiator is in the way. Has anyone replaced this before and if so do you have any DIY advise? Thanks.
tbsi430 is offline
post #2 of 12 (permalink) Old 11-25-2007, 02:02 PM Thread Starter
tbsi430's Avatar
Answered my own question. I was able to pull (maneuver) the fan shroud out without removing the fan, pull the (front) plastic dual fan grill cover out (with metal body molding attached to it) and then push the radiator forward enough to allow the idle bolt to be pulled out clearing the radiator. Now I'll have to wait until tomorrow to pick up a new pulley, since today is Sunday, and then put her back together. Belt bought for $40.00, pulley at dealer should be around $50.00 - 60.00.
tbsi430 is offline
post #3 of 12 (permalink) Old 11-25-2007, 02:07 PM
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: 2002 CLK430
Quoted: 2 Post(s)
The Mercedes-Benz service DVD says the fan and the fan shroud both have to be removed. Are you saying the tensioner bolts don't clear the radiator with the shroud out of the way?
MarcusF is offline
post #4 of 12 (permalink) Old 11-25-2007, 02:09 PM
MarcusF's Avatar
Quoted: 2 Post(s)
Whoops! You were fixing it while I was looking it up. Want to post any photos? Maybe a write-up? Thanks
MarcusF is offline
post #5 of 12 (permalink) Old 11-25-2007, 08:14 PM
Date registered: May 2005
Vehicle: 99CLK320
I believe this was a MB recall issue. No?
dlbehrns is offline
post #6 of 12 (permalink) Old 11-26-2007, 02:20 PM Thread Starter
tbsi430's Avatar
You're correct, there was a similar recall but my CLK had the correct part installed during manufacturing. It was the harmonic balancer that was recalled not the idler pulley. When I get home to put everything back together I'll take some pics and post them tomorrow. The idler puller was only $19.50 at the dealer. I was actually able to remove the idler pulley bolt by removing the shroud and pushing the radiator forward a bit. Otherwise, correct, the bolt would not clear the radiator. I actually had the belt in place without removing anything when I noticed a pulley was gone. I found the remnants laying on the plastic cover under the engine (bearings, plastic pieces, metal rings and of course what was left of my belt!).
tbsi430 is offline
post #7 of 12 (permalink) Old 11-27-2007, 12:39 PM Thread Starter
tbsi430's Avatar
Installation pics.
Name:	CLK Pulley 004.jpg
ID:	151325   Click image for larger version
Name:	CLK Pulley 002.jpg
ID:	151326   Click image for larger version
Name:	CLK Pulley 001.jpg
ID:	151327   Click image for larger version
Name:	CLK Pulley 005.jpg
ID:	151328   Click image for larger version
Name:	CLK Pulley 006.jpg
Name:	CLK Pulley 007.jpg
ID:	151330   Click image for larger version
Name:	CLK Pulley 010.jpg
ID:	151331   Click image for larger version
Name:	CLK Pulley 009.jpg
tbsi430 is offline
post #8 of 12 (permalink) Old 11-27-2007, 07:05 PM
Date registered: Nov 2007
Hey People ,
I have a 91 300te and I need to know what size nut/bolt the Idler Pulley is held in with ..any ideas?
dnswwood is offline
post #9 of 12 (permalink) Old 12-28-2011, 02:52 PM
unlukky's Avatar
Vehicle: 2006 CLS500
Question
This is a very old post, but hopefully you still monitor. How do you take the plastic bolt cover off? I want to be sure before I destroy it. Is it just a snap on fit? What size was the bolt for the pulley? Size of the bolt for the belt tensioner?
Thanks in advance, John
--John
2006 CLS500
unlukky is offline
post #10 of 12 (permalink) Old 12-28-2011, 03:37 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 17 Post(s)
It just snaps off, little friction ears hold it in place. I did a DIY for it that is at Benz Obsession, as noted there I used the side of the knife blade on my mini-Leatherman. It's on the M112 so no other parts need to be removed, not even the belt, really, you have more to do with the V8 M113. But here is the DIY, there are some other pics as well that show the hidden damage before the failure. Definitely something that should be done by 80 or 90 thousand miles, particularly given how inexpensive the part is.
The bolt is a T-50 Torx.
Good luck.
Check Codes is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > W208 CLK Class
User Tag List
Changing Idler Pulley? sstomcat W163 M-Class 1 10-04-2007 07:27 AM
What's an idler pulley? KTT R/C107 SL/SLC Class 7 01-10-2007 09:16 AM
Ac Idler Pulley Frozen! Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 5 12-28-2006 07:09 PM
'76 300D idler pulley otm646 Vintage Mercedes-Benz 1 11-08-2006 07:10 PM
Serpentine belt - idler pulley Geoff R170 SLK Class 2 05-08-2002 08:10 PM
