Old 04-04-2007, 10:22 AM   #1 (permalink)
Date registered: Apr 2007
Vehicle: 2002 CLK 320 Convertible
Unhappy 1 Malfunction - what is this?
I'm new to MB and just bought a 2002 CLK320 Cabriolet. The dash says "1 Malfunction" - I want to know what this means? I've read some posts and still can't figure it out. I don't have the SOS service (teleaid?) hooked up and I don't have the phone hooked up - could that be it??? It just says "SOS not active" and "NO PHONE" on the dash - I don't see anything else showing up. Should I be concerned about this? It passed the emissions test so I think it's not something with that. HELP!
Carl Osborne is offline   Reply With Quote
Old 04-04-2007, 10:34 AM   #2 (permalink)
Deltasonik's Avatar
Date registered: Sep 2006
Vehicle: 2003 Ford Ranger kickass edition. Soon 2003 SL55
check all of your bulbs.. sometimes if a bulb is out that you dont notice it will say 1 Malfuction (unless its a headlight or a foglight). Check the ones on the bottom of the door as well as the license plate. Just a thought.
Deltasonik is offline   Reply With Quote
Old 04-04-2007, 10:38 AM   #3 (permalink)
I'll check but all of them on the outside of the car are working. I will check the others inside - thanks!
Old 04-04-2007, 10:44 AM   #4 (permalink)
whodatis's Avatar
Date registered: Oct 2006
You probably need to have the error codes read to know for sure what the problem is. I heard that AutoZone will hook the car up (free) to pull those codes.
Don't feel bad. I don't have ANY malfunctions and I failed emissions (Mass air meter problem)!
whodatis is offline   Reply With Quote
Old 04-04-2007, 11:30 AM   #5 (permalink)
ExEngineer's Avatar
Date registered: Sep 2005
Vehicle: '02 CLK55
The red SOS button on your headliner may be stuck down. That will attempt to activate the teleaid system and give an error if you have no teleaid.
Also, the mute or dial buttons on the steering wheel may be stuck.
ExEngineer is offline   Reply With Quote
Old 04-04-2007, 12:22 PM   #6 (permalink)
Jennifer Shea's Avatar
Date registered: Jan 2007
Vehicle: 2002 Mercedes Benz CLK430
same thing on my 2002 CLK430. Dealer said it is because I don't have my teleaid hooked up. hasn't caused any problems, just annoying to see when i shuttle through my menu of options.
No biggie,
Jen
CLK430 Benz
Jennifer Shea is offline   Reply With Quote
Old 04-04-2007, 12:48 PM   #7 (permalink)
Thanks
Thanks, I may take to autozone and have them check. I had heard that same thing about the teleaid - annoying to say the least if that's the problem.
I know the SOS button is NOT stuck. I have been trying all of this stuff out. It has theoriginal mercedes phone but it's not hooked up but I tried it and it did call but then came back with "thisis not connected to a service - enter credit card info to use it" or something like that. I will see if Autozone can tell.
Thanks again
Old 04-04-2007, 12:58 PM   #8 (permalink)
mdvijay's Avatar
Date registered: Apr 2005
Vehicle: SL55,G500,C320,560SL,300SDL
that means you are not tele-aid subscriber...you must have a tele-aid and it must be activated thru mbusa...then this message will disappear...
vijay
mdvijay is offline   Reply With Quote
Old 04-04-2007, 02:16 PM   #9 (permalink)
nmilsaps's Avatar
Date registered: Mar 2007
Vehicle: 2001 CLK 430
Here is my situation (recently bought a 01 430)... I have the same malfunction light. It is from the SOS/Teleaid service, so the dealership said. They also said that error will be there until you subscribe for the service. Screw that.
So I went home and push the button, it dialed the service and they asked what my problem was. So I guess i do have service for that from the previous owner.
I went back to the dealership, they gave me a main number to call at Mercedes. I've yet to call them because I don't want that cancelled, I guess. I'll never use it, but free is always good. haha.
I've read in the forum, that some people have had the error taken off by some dealerships.
Also, if your steering wheel has the controls where you change the menu, volume, ect... you can just push any one of those buttons to get the warning to go away when you start the car.
I do have another malfunction with the lights, the rear fog/parking light, but that malfunction only comes on if i try to turn on the rear fog/parking light. And it says to "check lights" or something of that sort.
nmilsaps is offline   Reply With Quote
Old 04-04-2007, 02:25 PM   #10 (permalink)
ExEngineer's Avatar
Vehicle: '02 CLK55
As to the dealership removing the teleaid malfuction error, I received that error when I removed the MB GPS receiver. My local dealer said they could not code out the error. However, when I went back another time, I asked again and they were able to turn off the error. Its been fixed ever since.
Note, though, that this was not a "NO PHONE" error, so results could vary.
'1 malfunction' paul001 W245 B-Class 8 01-15-2007 08:25 AM
1 Malfunction osdesierto W210 E-Class 16 11-22-2006 12:51 PM
1 malfunction Old Otto W210 E-Class 11 06-15-2005 07:13 AM
First Malfunction RonJeffries R171 SLK Class 0 04-15-2005 05:51 PM
1 Malfunction ????? Guest (MBNZ) W203 C-Class 2 07-08-2002 06:37 PM
