Old 03-22-2007, 01:05 PM   #1 (permalink)
Date registered: Jan 2007
Front Lowering Help - Step by Step
Hi,
I'm a new member and was hoping to get some quick and dirty step by step instructions on how to install lowering springs in the front of a W208 CLK. I did the rears yesterday with no problem and didn't need to use a spring compressor but I know I will need to for the front. Any help would be greatly appreciated.
Thanks
-Rostock
Is this still the correct procedure:
1)Put car on jack stands.
2) Remove wheel.
3) Loosen shock and sway bar end from lower control arm.
4) Support lower control arm with jack.
5) Compress Spring.
6) Lower control arm and remove compressed spring.
7) Install new compressed spring with new spring pad.
8) Uncompress new spring.
9) Raise lower control arm and reattach shock and sway bar end.
10) Reattached wheel.
11) Remove car from jack stands.
rostock is offline   Reply With Quote
Old 03-22-2007, 04:11 PM   #2 (permalink)
da_guitarist's Avatar
Date registered: Aug 2006
Vehicle: 01 CLK55
This is more or less correct. If you do it just right, you can get the new spring in without compressing it. After you loosen the shock, loosen the bolt in the picture below, but do not take the nut off. Beat on this piece until it drops to the nut...probably gonna have to beat the $%@# out of it. This gives you another half an inch or so of clearance. It will take an impact wrench to loosen it and re-tighten it. The suspension will lower and almost catch by the brake line. Make sure your brake line doesn't get too much tension on it. After all this, when you compress the spring (u can use one of the ones at autozone, it's $50 deposit, but you get it all back. aka free) you'll pull it right out with the spring bad. The new spring pad and spring should fit in without being compressed. Makes life a little easier. I have more pics if you or anyone else is interested. Planning on posting a DIY one day.
da_guitarist is offline   Reply With Quote
Old 03-22-2007, 05:08 PM   #3 (permalink)
Portillos beef.....dipped
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK GoPed and a coupla Volvo semi's, c'mawn?
Yeah. If you can do it without removing the sway arm you can get away with not having to do an alignment.
-Pointless liar and inventor of the Bizzy Buzz Buzz.
Silence is Golden, Duct Tape is Silver.
ThrillKill is offline   Reply With Quote
Old 03-23-2007, 11:07 AM   #4 (permalink)
Thank you for the help! Much appreciated.
Step-by-step replacement of tail lamp lens for 126? Lazzarusman W126 S,SE,SEC,SEL,SD,SDL Class 4 06-20-2006 07:43 PM
Need step by step instructions for installing amp in 1999SLK230 Jeffrimerman Audio & Telematics Forum 0 05-26-2003 11:17 PM
Step by step procedure to turn on chirping for locking and unlocking (does not disable panic button) Gene R170 SLK Class 3 03-24-2003 05:32 AM
Can Linh or someone provide me with simple step by step instruction to change my shock on CLK? TIA Jeff W208 CLK Class 1 04-23-2002 10:34 AM
Brian, step by step instructions for repairing paint chips? SteveL R170 SLK Class 2 10-27-2001 07:41 AM
