| Re: other cars, if you can get to the lowest point in the oil pan with the line it should work fine.
I don't think I'd try it for a tranny, though, because changing fluid is only 1/3 the issue. When you drop the pan you then let more fluid drip out of the valve body and passages which takes some time, so you'd have to keep coming back to the topsider periodically. Also, there is always a gummy film of stuff lining the bottom of the pan, so after you pull it off you can clean all that out. Last is the filter; the only way to change that is to pull the pan, so you're back at square one.
Take care and enjoy the ride,
Greg
When you fail to learn from any mistakes, that's government. |
