SRS warning light - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 01-30-2007, 05:32 AM Thread Starter
ssass24's Avatar
Date registered: Feb 2005
Vehicle: 2001 CLK-55
SRS warning light
I see a few old posts on this, but no real resolution. I've got the SRS light on steady...so following the advice from the boards, I checked all the connectors under the seats. Everything looked hunky-doory there, so I gave up and took it to my local rapist, err....dealer.
As expected, they told me the car would have to be completely disassembled and put back together. Not really, but they want $2k for the passenger airbag module to be replaced.
I work for a tier 1 automotive supplier, and we deal with airbags. Even for domestic cars, this is one of the most quality-controlled parts on the entire car...and it has no moving parts. I find it hard to believe that it would just fail for no reason. My guess (from reading posts) is that it is the passenger sensor in the seat. Does this sound reasonable? Does anyone have a part number/approximate cost for the part?
ssass24 is offline
post #2 of 7 (permalink) Old 01-30-2007, 07:38 AM
Date registered: Nov 2006
Vehicle: 88 420 SEL, 99 CLK 320 Cab-SOLD
SRS problems on a 2001
have you checked with the NTSB to see if there are any other complaints, I think this would be a safety issue on a 2001 that MBUSA should fix under a service campaign.
That is where I would start before I pay any $$ to the dealer.
Palm Tree Mechanic is offline
post #3 of 7 (permalink) Old 01-30-2007, 12:57 PM
Date registered: Apr 2006
Vehicle: 08E350,08C350
This SRS light problems happen to me : for sure when you snap the seat belt buckle, make sure it snap in GOOD (I guess that my old car 95/94 MB, the buckle sensor is old, when snap the buckle in, it really DOES NOT go all the way), the SRS light come on & off while I am driving, when I get home, spray a little bit of WD40 to the buckle holder, the SRS light do not show, when I snap, the buckle go in the holder smoothly. Try the easy fix first to see what happen, before you put in a lot $ for the dealer to fix.
00CLK208 is offline
post #4 of 7 (permalink) Old 02-06-2007, 07:19 AM
Date registered: Jun 2006
Vehicle: 2001 clk 320 cabriolet
get an indy star diagnosis
My local MB specialist did this (for £40) fault was "high resistance wire between passenger door airbag and squib" This was a stored fault and the light went out on clearing it, 2 weeks later wife opens door, on it comes. Now thinking about stripping door down to see if any wires look damaged in hinge area. Trouble is wires have to have the correct resistance for that damn brain to be happy.
mike griffiths is offline
post #5 of 7 (permalink) Old 02-06-2007, 10:22 AM
Date registered: Sep 2005
Vehicle: 2001 CLK 430 Cabriolet
Had the same problem with my 2001 CLK 430. Problem was a bad switch in my seatbelt buckle. Got it replaced, never had that problem again.
jjklar is offline
post #6 of 7 (permalink) Old 02-14-2007, 08:51 AM Thread Starter
ssass24's Avatar
The light comes on as soon as the car is started. Could that still be a seatbelt switch issue?
They pressure you into paying the $$ to fix it, because they say if there is any fault, the aribags will not deploy in an accident...which is probably true.
ssass24 is offline
post #7 of 7 (permalink) Old 07-12-2008, 04:06 PM
deyainrdy4ds's Avatar
Vehicle: w208
Send a message via AIM to deyainrdy4ds
weird problem ...
mine stays on , but dimly....turn on the car - and its gone.... another symptom was that my horn just stayed on and lights were flashing ...wtff can this be..the flashing stops when i unlock or lock the door...but then horn only goes off when i put the key in and turn it once...remove it and it starts again...after just doing it a couple times it finally stopped but the SRS light is still dimly lit when the car is off....
any ideas?
deyainrdy4ds is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > W208 CLK Class
User Tag List
SRS Warning Light AxelWulff W126 S,SE,SEC,SEL,SD,SDL Class 8 02-10-2006 02:55 PM
SRS Warning Light Brecon W210 E-Class 0 06-01-2003 03:31 AM
re: SRS warning light Jhon Suaco W201 190 Class 2 02-14-2003 03:13 PM
SRS Warning Light Silverbullet W210 E-Class 1 12-12-2002 01:37 PM
SRS WARNING LIGHT jeffsf W124 E,CE,D,TD Class 6 08-16-2002 10:52 AM
