Fuel Filter Location - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 09-09-2006, 12:47 PM Thread Starter
Hello, I have a 2000 clk 430 and I can't find the location of the fuel filter. I found a couple of posts on here that are kind of vague. It says its under the car on the right side near the rear tire. I just spent 15 minutes trying to look under my car but I didn't see anything. Can anyone please describe the location in more detail or maybe a picture? Also, can I access it and replace the filter without having to lift up the car?
willy2369 is offline
post #2 of 17 (permalink) Old 09-09-2006, 01:25 PM
jtbeche's Avatar
Date registered: May 2005
Vehicle: 02 E55; 99 CLK430 (Sold)
I think, but I'm not positive that you have to take the, uh, wheelwell cover (I can't remember the right word) off on the drivers side rear wheel to get to it. I'm sure that didn't make sense. Sorry I can't be of more help.
The Thrill is back!
jtbeche is offline
post #3 of 17 (permalink) Old 09-09-2006, 01:44 PM
Date registered: Jan 2006
Vehicle: CLK430 Cabrio
Send a message via AIM to SICK55
its a piece of plastic that needs to be removed. its right infront of the rear left tire. ill be able to feel a lose piece of plastic under the car if you touch it.
if you still cant find it try to take a pic of it.
SICK55 is offline
post #4 of 17 (permalink) Old 09-09-2006, 02:28 PM Thread Starter
Thanks for your help guys but unfortunately you confused me even more. The other posts that I saw said that it was on the passanger side (right). I'm pretty sure it's not under the wheel well, that wouldn't make any sense, there is no way they'd put fuel lines in the wheel well. As far a plastic cover, is it just a snap on or is it secured by a screw? I found what looks like a small plastic cover on the LEFT side, right at the edge of where the wheel well starts and it's secured by a nut. Is that it? Has anyone here actually replaced one or have seen it done?
post #5 of 17 (permalink) Old 09-09-2006, 05:18 PM
Date registered: Jun 2005
Vehicle: 2001 CLK 320 and 2002 ML 320
Smile Fuel Filter Location
The fuel filter is located (if the vehicle hoisted) near the rear axle in the middle. It silver and resembles a can os "Coors" beer can. Hope that helps.
sazodada is offline
post #6 of 17 (permalink) Old 09-09-2006, 05:42 PM Thread Starter
Hmm, every response is different. Left side , right side, inside wheel well and now in the middle. lol Why can't it just be under the hood like in all the normal cars. Mercedes has to make everything difficult. I guess I'll keep looking.
post #7 of 17 (permalink) Old 09-09-2006, 05:51 PM
I found what looks like a small plastic cover on the LEFT side, right at the edge of where the wheel well starts and it's secured by a nut"
thats it. dont forget that mbs have two one under the car and another under the hood.
hope the helps
SICK55 is offline
post #8 of 17 (permalink) Old 04-08-2010, 07:24 PM
Date registered: Aug 2007
Vehicle: 2002 CLK430 Convertible
Send a message via Skype™ to kgantzer
hope the helps
Does anyone have a pic of the fuel filter location under the hood? Or can you try to describe it in some detail?
Thanks.
kgantzer is offline
post #9 of 17 (permalink) Old 04-08-2010, 11:38 PM
MarcusF's Avatar
Date registered: Apr 2005
Quoted: 2 Post(s)
"under the hood"? If the CLK has a filter under the hood, I can't find it in the WIS, or in the STAR Classic DVD, and I can't find a part number for it. I've changed the one "under" the car several times. The red arrow in the photo points to a silver can with a plastic cover underneath it. That can is the filter, and that's what I've changed.
Rear of the car, to the right of the diff, you can't miss it.
MarcusF is offline
post #10 of 17 (permalink) Old 04-09-2010, 05:00 AM
Date registered: Feb 2003
Vehicle: 2002 CLK55///04BMWxi///2010GLK350
Quoted: 5 Post(s)
Marcus as usual has cleared up your confusion. A suggestion when changing, mark the lines so you don't confuse them when changing. You will need new hose clamps (originals rarely hold after removing).
2002 Obsidian Black CLK55
2010 GLK350 4matic
tomtomtomtom is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > W208 CLK Class
User Tag List
Location of Fuel Filter on 190E 2.3 RicoDirenzo W201 190 Class 4 05-20-2006 11:28 PM
fuel filter location my260e W124 E,CE,D,TD Class 7 02-06-2006 04:34 PM
fuel filter location Fsuperb W163 M-Class 9 09-22-2005 09:18 PM
1999 ML430 Fuel filter location????? HappyML430 W163 M-Class 2 05-06-2005 04:57 PM
W220 Fuel filter location TheGame W220 S-Class 0 02-01-2005 10:13 PM
