Old 11-14-2005, 05:25 PM   #1 (permalink)
Date registered: Apr 2005
Vehicle: 2002 CLK430
Send a message via AIM to nycxed
how do i reset the service light ?
i just did an oil change myself... and will do the rest later like filters and stuff... but how do i reset the service light? i read some of the old post... but it was too damn confusing... can someone please help?
nycxed is offline   Reply With Quote
Old 11-14-2005, 06:10 PM   #2 (permalink)
Date registered: Aug 2005
Vehicle: 2002 CLK 55 AMG Cab
RE: how do i reset the service light ?
Here goes, this is from page 105 of the operator's manual I ordered for my 2002 CLK.
The counter can also be set by any individual:
Turn the electronic key in steering lock to position 2.
Press page up/down button on steering wheel to call up the trip odometer/main odometer.
Up or down arrow until you get to the FSS (flexible service system) indicator (that's the message that came on in the first place).
Press the R button, on the instrument cluster for approximately 4 seconds.
The multifunction display will show a question asking if you want to reset.
Press the R button again for approx. 4 seconds.
According to the manual, you should now be reset for another 10K miles.
indyhiggie is offline   Reply With Quote
Old 11-16-2005, 11:38 AM   #3 (permalink)
Date registered: Nov 2005
Hi,
I'm new to this forum and have a hard time finding a button to post. I have a few questions. First the check engine light keeps popping up and go away every 2 days or so. I asked the mechanic (not from MB)and he told me that probably the airflow thing. Do you know what he is talking about..anyone has similar problem? my other question is that me car clk 430 convertible required a service B and I checked and found out that they only need to change the oil, and the dust filter...beside that they just check for fluid....Is it easy to change the dust filter? and the air filter? what is a different between these 2? Thank you very much....please help.
430convertible is offline   Reply With Quote
Old 11-16-2005, 12:49 PM   #4 (permalink)
jtbeche's Avatar
Date registered: May 2005
Vehicle: I used to drive a CLK
Whew....lots of stuff there. I'll try and help with some of it. Well you "might" need a new MAF. You also might need a new oxyen sensor. Your best bet is to take it into AutoZone or a parts store like that when the light is on and have them check the codes. They should tell you what the problem is.
I personally don't remember what is involved with the B service, but if you're right then changing the air filter is very easy. The dust filter I'm assuming is the cabin filter. Another easy change. I think there have been posts on both on how to change. The oil change....well a lot of people recommend a topsider to do this. That way there's no getting under the car and it gets most of the old, bad oil.
Don't know if that was much help.
The Thrill is gone.
jtbeche is offline   Reply With Quote
Old 11-16-2005, 01:10 PM   #5 (permalink)
air filter and dust filter
Thanks,
Are both the filters under the hood, where are they located? and there is no electrical wiring that I have to deal with, right? Does it really matter that I have to buy the filters at the MB dealer or I can just buy them at Kragen or other auto store?
Old 11-16-2005, 01:47 PM   #6 (permalink)
jtbeche's Avatar
RE: air filter and dust filter
Obviously the air filter is under the hood. Do a search on amg intake and I bet you find how to swap the intakes out. I know you're not changing your intake but I bet there are enough pics there for you to understand how to take the intake off and undo the torx screws and change the filters. I say if you're going to change them put K&N's on or Green filters. A lot of people will tell you not to put K&N's because if you oil them too much you'll screw things up. The cabin filter is above the foot well on the passenger side. I know there have been pics and descriptions taken of this as well. If not on this site then at least on mb world . org (take out the spaces).
Old 11-16-2005, 08:42 PM   #7 (permalink)
Thanks, I changed the cabin filter...extremely easy...3 screws underneath the dash board and 1 screw on the left side of the passenger foot...I also changed the air filter too. I didn't know my car requires 2 instead of 1. I have a question though....does it matter if I buy the air filter at Kragen or at MB dealer? Also, the K&N reuseable...is it worth it? recommended? Thanks,
