Old 09-22-2005, 11:14 AM   #1 (permalink)
Date registered: Sep 2005
Vehicle: 1999 CLK430
OBD Codes?
My check engine light has been coming on intermittently, I took it by auto zone and had the codes checked they were P0173, P0170, P0161, P0156. I think it is the MAF but not real sure. It is a 99 with 60,000 miles on it. It has also started makeing a tapping noise at start up, almost sounds like a quiet diesel for a couple minutes then goes away. Any thoughts.
gillejb is offline   Reply With Quote
Old 09-22-2005, 02:12 PM   #2 (permalink)
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: CLK430
RE: OBD Codes?
P0156 - O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0161 - O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0170 - Fuel Trim Malfunction (Bank 1) check vaccum leaks first or
P0173 - Fuel Trim Malfunction (Bank 2)
Does the car still have the original seven year old O2 sensors?
MarcusF is offline   Reply With Quote
Old 09-22-2005, 02:25 PM   #3 (permalink)
RE: OBD Codes?
I bought the car in December so I would have to assume so.
Old 09-22-2005, 03:16 PM   #4 (permalink)
Date registered: Jul 2004
Send a message via MSN to EdB430CLK
RE: OBD Codes?
Hey JB,
I would check the Pre-post O2 sensor first. I think that is one of the problems of going to Auto zone for code reading because their reader might not be able to give you a specific id location for the 02 sensor- eg. pre cat/bank 1/sensor 1, etc. If you are in the Wash metro area i might be able to help you out if you are going to DYI. I have a Snap-On Modis scanner that will give you alot of dealer-specific info...
Ed
EdB430CLK is offline   Reply With Quote
Old 09-22-2005, 03:22 PM   #5 (permalink)
RE: OBD Codes?
Opps, missed that on...
DIY
Old 09-22-2005, 03:23 PM   #6 (permalink)
RE: OBD Codes?
FORGET IT>>>>
trying to type toooo fast..!!!!
onE
Old 09-22-2005, 03:34 PM   #7 (permalink)
MarcusF's Avatar
Vehicle: CLK430
RE: OBD Codes?
Not to hijack the thread, but Ed, where did you get the SnapOn reader; The truck, Internet, or??
Old 09-22-2005, 03:47 PM   #8 (permalink)
RE: OBD Codes?
Ed, Thanks for the offer but I live in LA, by that I mean Lower Alabama. I think I will start with the O2 sensor, then move on from there. It hesitates on acceleration as well so I might just change the MAF as well. Thanks
Old 09-24-2005, 12:23 PM   #9 (permalink)
Vehicle: 2002 CLK430
Send a message via AIM to nycxed
RE: OBD Codes?
where i get those chrome thing around the windows?
nycxed is offline   Reply With Quote
Old 09-24-2005, 07:00 PM   #10 (permalink)
Vehicle: CLK430
Send a message via AIM to sicrx65
RE: OBD Codes?
I think only pre 2000 models came with the chrome trimming. IMO I like the blacked out window trim on the new models..
sicrx65 is offline   Reply With Quote
