Old 09-22-2005, 08:16 AM   #1 (permalink)
Date registered: Sep 2005
Problem with transmission need advice.
I have Mercedes CLK 320 2001.I was driving car towards my home yesturday and i noticed transmittion light come on(orange light on the right side.)And then i pulled over by traffic lights vehicle start shaking a bit.I wonder is transmission Oil gone or is it damage to the automatic transmission.Cuz then i driving a car it has no power as it had before.I mean it swiches the gears but car doesn't go that fast as before.Then i opened a hood ,couldn't find transmission dipstick,so i couldn't check the level of the oil.Does any one knows where can i find it or where can i fill in transmission fuild?
nfinite is offline   Reply With Quote
Old 09-22-2005, 09:02 AM   #2 (permalink)
Portillos beef.....dipped
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK GoPed and a coupla Volvo semi's, c'mawn?
RE: Problem with transmission need advice.
Welcome.
The CLK has a sealed transmission, there is no dipstick. It sounds as if you've gone into "limp mode". This is something you should definately take to a qualified mechanic to resolve. If your transmission is repairable, you will save the $4000+ to replace it. I would have it towed rather than drive. How many miles are on it?
-Pointless liar and inventor of the Bizzy Buzz Buzz.
Silence is Golden, Duct Tape is Silver.
ThrillKill is offline   Reply With Quote
Old 09-22-2005, 10:23 AM   #3 (permalink)
is 59k miles on it i was driving about 5 miles since that light come on.I hope that tranny didn't damage yet.
Old 09-22-2005, 10:31 AM   #4 (permalink)
ThrillKill's Avatar
I'm thinking if you were stopped at a light and it was shaking, that doesn't sound like the trannie. Do you have a warranty?
Might be the harmonic balancer which has been recalled and can shred your belts.
http://www.alldata.com/tsb/Mercedes-Benz/1112342400000_1116486000000_2005020003/1.html
Old 09-22-2005, 10:48 AM   #5 (permalink)
To be honest then the car is on the Neutral gear, RPM keeps on 10k.But then i put Drive gear it goes below 10k ir reaches 5k then car starts shaking.And then i press accelerator it starts shaking more and goes quite slowly.I mean it doesn't have that much power as it had before.I wonder is it problem with a tranny or it might be some lead come of and computer blocking RPM to avoid damage?
Old 09-24-2005, 06:08 PM   #6 (permalink)
Date registered: Mar 2003
Sounds like a vacuum leak to me.
TresX is offline   Reply With Quote
