was leaking air.. am shipping it off tonight to tampa to get it fixed.. guy said it should be no problem and cost around 100 bucks.. hoping not to have some horror stories that i hear usually.. this is actually better than having to buy a new tire.. considering they are like 240 a pop.. unless he ruins my rim trying to fix it..
At night my thirdeye is as bright as a streetlamp.
1 tried rim repair 100 bucks
1 new rim and tire 1000 dollars
300 dollar fuse change out 300 dollars
service a 500 dollars
changed maf sensor 700 dollars
still more coming.. had an abs light come on so i gotta get that checked out.. and i currently have 1 rim being repaired as i type this.. dunno how much that is gonna be..
not to mention i still have brand new shocks spring pads brembo rotors and porterfield brake pads waiting to be put on .. just aint had a chance to bring it to my boy cause all this shit has been happening..
Vehicle: ML CLK GoPed and a coupla Volvo semi's, c'mawn?
RE: so the rim was bent too much
Phade - 9/21/2005 2:19 PM
Before you go to the dealer for the ABS, do you have 4 wheels the same size on now? You said one was being fixed, If you've got the little oem wheel on that could be your problem.
well i haven't driven the car since i put the stock wheel on there as a spare.. but the abs light came on a few days after i had putting my 19's back on.. and didn't come back on again after that.. think it might be jsut the change of the wheels? if so good..
You guys HAVE to learn how to do your own diagnostics. The dollar amounts that you're paying the dealer are obscene. Changing the parts on a Mercedes-Benz is no more difficult than it is on most other cars. The good news is, running diagnostics on a car with OBD-II is much easier than the old days when I first got started. In some of the other car clubs that I'm currently in (and have been a member of in the past), we've had meets where we show the new guys how to run diagnostics and how to make adjustments. Running diagnostics with a scanner is a breeze.
