RE: HELP!! Accessing fuel sending unit/s of a 2001 CLK 430 coupe
There is no way to access those sensors without draining all of your gas. They are two of them and they are located inside the tank. Very messy job, if you don't have the right tools/equipment.
Try checking under your back seats if they are removable. It could be there. When you remove the seats look for something that looks like a metal cap thats dome shaped with 4 to 6 screws around it.
CH2iS* - 9/20/2005 12:25 AM
?? Don't tell me we have fuel in the interior of our CLK's. I don't think that ones allowed.
Thanks guys,
I did remove the lower seat assy. but didnt see any signs of an access cap. Looks like i might have to drop the gas tank and replace both units. My gas gauge started acting up...not reading a full tank...
i figured i would start there.
You don't have to remove the gas tank. The sensors are located on the bottom of the tank. You access them from under the tank. That is why you have to empty the gas tank! Because if you don't, all the gas will rush out when you remove the sensors. (They are essentially 2 plugs at the bottom of the tank, stopping the gas from coming out)
