Old 09-17-2005, 08:06 PM   #1 (permalink)
Date registered: Sep 2005
Vehicle: CLK430
Send a message via AIM to nycxedd
seats cant move back and forward
QUESTION!
i had to jump my battery with a battery pack cause it died. and i didnt do the ECU procedure YET cause i didnt know. from reading the procedure it didnt say anything about the seats cause im having problems with it. i had more then one passenger so i was letting them in from the passenger side... and after a while the seats wouldnt move back and forward but the rest works, so then i was letting them go in to the back from the driver side and now i have the same problem it wouldnt move back and forward. first i thought it was just the passenger seat and now mines? how i fix this?
nycxedd is offline   Reply With Quote
Old 09-18-2005, 03:20 PM   #2 (permalink)
D2k
D2k's Avatar
Date registered: May 2005
Vehicle: 05 A6 3.2Q, 07 A4 2.0T S-Line
RE: seats cant move back and forward
check the fuse in the trunk. I have this problem on mine. Turns out I need a new seat frame with the new motors. I have some aftermarket wiring going through the seats though so I'll just leave it alone and change the fuse again when it blows. Just try not to move the seat back and forth too much (there's a way to disable to easy entry feature).
D2k is offline   Reply With Quote
Old 09-18-2005, 03:24 PM   #3 (permalink)
Vehicle: CLK430
i fixed it!!! i thought it was the fusebox in the front but it was fine... it turned out to be the fusebox in the trunk which i wasnt aware of thanks guys
