Old 09-16-2005, 04:59 AM   #1 (permalink)
CLocKed@240's Avatar
Date registered: Sep 2005
Anyone heard of this before?
Hi Guys,
Drove 30 minutes to a restaurant, parked, had a meal. When I came out, the car refused to start. It cranked OK, many times, but no start. There was even enough power to put the convertible roof up. The only thing I noticed was that there was no sound of the fuel system 'juicing up' asw normal. A recovery truck brought us home and I left the car for the night.
The next morning, the car started. I used the car that day with no problems. Not happy with what happened,I tested the battery. It was below par. With a new battery, everything is back to normal.
I can't understand how a sub-standard battery can crank the engine many times, but not operate the fuel system. Any thoughts?
Cheers,
Steve.
CLocKed@240 is offline   Reply With Quote
Old 09-16-2005, 09:24 AM   #2 (permalink)
str8ridin's Avatar
Date registered: Jun 2004
Vehicle: 05 E55
RE: Anyone heard of this before?
It could be your crankshaft position sensor. It is very sensitive to heat, and when it's hot, the car won't start.
str8ridin is offline   Reply With Quote
Old 09-27-2005, 11:12 PM   #3 (permalink)
MylesC's Avatar
Vehicle: 2000 CLK 32
Just had my crank sensor replaced - exact same symptoms, apparently a weakness on the CLKs (mine's 00). I think it's about $250 parts and labor, mine was done under warranty. The Merc Roadside Assistance dude told me what the problem was when he answered my suspected dead battery call....
MylesC is offline   Reply With Quote
Old 09-28-2005, 01:42 AM   #4 (permalink)
Date registered: Mar 2003
Stra8ridin is on the money. It is most likely the CPS. Please don't go to the dealer. You can purchase the part for $35 from carpartstogo.com. Install will take you 5 - 10 minutes.
*edit* they seem to be out of them at the moment. If you can't find it online, atleast pick it up from the dealer and put it in yourself. If you take it in to the dealer, they're gonna charge you for diagnosis+++
TresX is offline   Reply With Quote
Old 09-28-2005, 11:27 AM   #5 (permalink)
Date registered: Nov 2003
Vehicle: Slow benz
Anyone have step by step writeup on how to replace the crank positions sensor?
blackbenzz is offline   Reply With Quote
Old 09-28-2005, 12:46 PM   #6 (permalink)
It's in str8ridin's write up on mbw****.org
Old 09-29-2005, 02:22 PM   #7 (permalink)
Vehicle: Slow benz
ok cool, thanks. My car shut off on me today at a light but started right back up, you think this could be the problem?
Old 10-09-2006, 09:58 PM   #8 (permalink)
Date registered: Mar 2006
Vehicle: 1999 CLK320
Looking for your writeup on the CPS sensor, on how to install it. Is it still listed? Thanks for your help in advance.
C Money is offline   Reply With Quote
Old 10-10-2006, 09:10 AM   #9 (permalink)
Date registered: Oct 2005
hey guys! interesting topic. i have a 99clk320.
what happens to me once in a while is when i turn the ignition key, it just clicks with about 1 second of cranking. i turn it back then try to ignite the engine then same thing,, click and a second of cranking.
normally what i do is step on the gas pedal halfway then ignite the engine and vroom..it turns on. but isnt that annoying? what could it be?
could this be the CPS too? sparkplug? ignition coil? i dont think its the battery...
ehizon is offline   Reply With Quote
