Old 09-16-2005, 12:14 AM   #1 (permalink)
Date registered: Apr 2005
Vehicle: CLK430
Send a message via AIM to sicrx65
Faulty MAF??
Well this is repost from MBworld because no one has answered yet and I need help ASAP..
I got my 430 back today from the dealership for a service (oil change, and stuff like that). I also had them look over my check engine light that had been going off and on for the past month or so, the car hasn't been performing at its full potential. They told me that it was a faulty mass air flow sensor, so they replaced it. I just got home from cruising around for a little, and on the highway I decided to gun it to see if she would perform better. She defiantly did, but after gunning it a few times on a long stretch I decide to do it one last time. This last time I had the throttle at WOT, 2 seconds into it the engine just cut off for a brief moment and I let off the gas immediately. My car acts fine at all throttle positions except at WOT with the kick down petal depressed. I tried it a couple more times, it does it again. Has anyone ever had this problem? It seems as though only when the kickdown petal is activated for 2 seconds the engine cuts off and starts back up again. If I hold it at WOT and ignore the engine cut offs it still goes, but there is a problem. Do you think the MAF just needs more time to break in? Any comments?
sicrx65 is offline   Reply With Quote
Old 09-16-2005, 01:04 AM   #2 (permalink)
ClkE's Avatar
Send a message via AIM to ClkE
RE: Faulty MAF??
I recently changed my Maf after having your same symptoms. It choked at wot and started jerking when I hit the kickdown button before I changed it. Immediately after changing it the car ran like new no break in necessary. When you change your Maf it is highly recommended that you change your air filters at the same time. The dealer probably didnt change them. Maybe your filters are clogged. Also no one ever changes their fuel filter either and the dealer usually wont do it unless you ask. You should defininately change your fuel filter. I changed mine at the same time I changed my Maf and it was amazing how different the car felt.
I had a similar situation with the same symptoms involving performance loss on my Bimmer I ignored it and the fuel pump died because of a clogged fuel filter. So if you dont know when the last time it was changed change it asap.
ClkE is offline   Reply With Quote
Old 09-16-2005, 08:24 AM   #3 (permalink)
Date registered: Nov 2003
Vehicle: Slow benz
RE: Faulty MAF??
I just found out my fuel filter was never changed so i'm changing it today. Your problem doesnt sound like a MAF to me unless its sluggish throughout the power band, especially at the top end. Do you have access to diagnostic equipment?
blackbenzz is offline   Reply With Quote
Old 09-16-2005, 09:19 AM   #4 (permalink)
str8ridin's Avatar
Date registered: Jun 2004
Vehicle: 05 E55
RE: Faulty MAF??
If anyone needs DIY instructions on changing the fuel filter, let me know...
str8ridin is offline   Reply With Quote
Old 09-16-2005, 09:42 AM   #5 (permalink)
Vehicle: Slow benz
RE: Faulty MAF??
My friedn si going to do it for $30, I appreciate the offer though. For that price, its not worth trying to do it on the floor.
Old 09-17-2005, 12:13 AM   #6 (permalink)
DanStubbs's Avatar
Vehicle: CLK430
Send a message via AIM to DanStubbs
RE: Faulty MAF??
str8ridin - 9/16/2005 10:19 AM
GIMMIE!
DanStubbs is offline   Reply With Quote
Old 09-17-2005, 12:44 AM   #7 (permalink)
DanStubbs's Avatar
Vehicle: CLK430
RE: Faulty MAF??
Dude..........never pay the dealer to replace the MAS. It takes like 5 minutes. Should have searched the board first. Oh well, live and learn.
Old 09-17-2005, 12:10 PM   #8 (permalink)
str8ridin's Avatar
Vehicle: 05 E55
RE: Faulty MAF??
DanStubbs - 9/17/2005 1:13 AM
GIMMIE!
Check the HOW TO Sticky on m b world . org in the W208 section that i put together. :)
str8ridin: 05 E55
Sold: 99 CLK430
Old 09-19-2005, 03:11 AM   #9 (permalink)
qslick74's Avatar
Vehicle: 2000 CLK
Send a message via AIM to qslick74
RE: Faulty MAF??
what's wot ??
you laugh cause i'm different, i laugh cause you're all the same
unknown
qslick74 is offline   Reply With Quote
Old 09-19-2005, 07:19 AM   #10 (permalink)
Portillos beef.....dipped
ThrillKill's Avatar
Vehicle: ML CLK GoPed and a coupla Volvo semi's, c'mawn?
RE: Faulty MAF??
Wide Open Throttle.
-Pointless liar and inventor of the Bizzy Buzz Buzz.
Silence is Golden, Duct Tape is Silver.
ThrillKill is offline   Reply With Quote
