Old 09-15-2005, 08:10 PM   #1 (permalink)
nellad's Avatar
Date registered: Sep 2005
Vehicle: CLK55, 65 Corvette
Send a message via MSN to nellad
Lowering my CLK55.....
I just bought my car and I need some advice. I want to know what is the best way to lower my car and keep as close to a stock ride as possible. I just put 19's on it, and now it needs to be dropped. Any advice?
nellad is offline   Reply With Quote
Old 09-17-2005, 12:16 AM   #2 (permalink)
DanStubbs's Avatar
Date registered: Apr 2005
Vehicle: CLK430
Send a message via AIM to DanStubbs
RE: Lowering my CLK55.....
I say buy Kleemann springs and dampers! Run you about 1600 in parts.
DanStubbs is offline   Reply With Quote
Old 09-17-2005, 04:07 PM   #3 (permalink)
nellad's Avatar
Thanks, I will look into both of these.
Old 09-27-2005, 08:05 AM   #4 (permalink)
Date registered: Feb 2004
Vehicle: 2001 CLK 430
Send a message via AIM to ChiCLK430
My old CLK 430 same wheels no DROP
My current 55AMG with drop
and the other pic is in the sognature line.
<size=5>Behind every Hot Chick, there is always a guy that's sick of banging her</size>
ChiCLK430 is offline   Reply With Quote
Old 09-27-2005, 03:13 PM   #5 (permalink)
Date registered: Nov 2003
Vehicle: Slow benz
Wow, I didnt notice you upgraded to a 55, congrats!
blackbenzz is offline   Reply With Quote
Old 09-29-2005, 01:05 PM   #6 (permalink)
blackbenzz - 9/27/2005 5:13 PM
worth it
Old 10-02-2005, 05:43 PM   #7 (permalink)
wmr120's Avatar
Date registered: Aug 2005
Vehicle: CLK55
nellad,
I also have a CLK55 and my advice would be to go with H&R springs and 17mm spring spacers all the way around. I've experimented with 9mm, 13mm, and 17 mm. Too make a long story short, if you don't put the 17mm's all the way around, you'll most likely find yourself rubbing in hard turns. That's been my experience at least. Also, you want to buy eccentric camber bolts for the front and a camber kit for the back since there will be quite a bit of negative camber. If you're interested, I have a rear camber kit from Renntech. The kit consisted of four camber bolts for the rear and only 2 needed to be used. Needless to say, I have 2 extra camber bolts that I can't use. The kit from Renntech costs $500 so if your interested, I'll cut you a pretty good deal.
wmr120 is offline   Reply With Quote
Old 10-02-2005, 08:52 PM   #8 (permalink)
Vehicle: 2002 CLK 55 AMG Cab
What year is your CLK55. Is it stock height for a 55, or has it been dropped too. It would be great to know the difference between a CLK430 not dropped, and the factory CLK55.
A simple measurement under the side of the car ground effects would be great. To make it easy for me to compare to my CLK55, which I think is still stock, please measure directly under the line made by the door meeting the body gap, on the end of the door where the handle is.
Thanks!!
[:D]
indyhiggie is offline   Reply With Quote
Old 10-14-2005, 10:35 PM   #9 (permalink)
nellad's Avatar
Indy-
Sorry it took so long to respond... My car measures 12-7/8" to the top of the rubber, on the bottom at the rear of the drivers door. And my car hasn't been lowered, bone stock right down to the purse scratches on the roof from the previous owner. I do have 19's though, 245/35 front & 275/30 rear.
wmr120-
What do you want for those camber bolts?
Old 10-15-2005, 01:58 AM   #10 (permalink)
qslick74's Avatar
Date registered: Jun 2004
Vehicle: 2000 CLK
Send a message via AIM to qslick74
CLK #2 in the back E class #1 pads in the front
you laugh cause i'm different, i laugh cause you're all the same
unknown
qslick74 is offline   Reply With Quote
