Old 09-10-2005, 09:21 AM   #1 (permalink)
Date registered: Aug 2005
Vehicle: 2002 CLK 55 AMG Cab
ESP and rear tire air pressure: how much do you run ??
I aired my tires up to the mid point between normal and heavy use: 2002 CLK55 AMG (cabriolet, more weight than coupe)
37 front
39 rear
They were closer to 32 front and rear prior,
Now, I can't even take off reasonably quick, without ESP taking over, and the throttle shut down that is induced.
What pressure do you run ??
I plan to go back down to 35PSI front and rear, and see how it goes.
indyhiggie is offline   Reply With Quote
Old 09-10-2005, 12:00 PM   #2 (permalink)
str8ridin's Avatar
Date registered: Jun 2004
Vehicle: 05 E55
RE: ESP and rear tire air pressure: how much do you run ??
Did this happen at regular psi?
I usually run factory setting as indicated in my owner's manual. If you increase the tire pressure, you can get better gas mileage and less traction (straight line), but you will wear out the inside of your tires pretty quick, depending on your speed and treadwear rating.
str8ridin is offline   Reply With Quote
Old 09-10-2005, 12:14 PM   #3 (permalink)
Portillos beef.....dipped
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK GoPed and a coupla Volvo semi's, c'mawn?
I'm running at 38psi for the mpg's. So far these Hankooks are showing no wear at 10,000 miles.
-Pointless liar and inventor of the Bizzy Buzz Buzz.
Silence is Golden, Duct Tape is Silver.
ThrillKill is offline   Reply With Quote
Old 09-10-2005, 12:36 PM   #4 (permalink)
I dropped back to 35 psi front, and 36 psi rear. Thanks for the info in my other post. The part that seems new, an wierd, the throttle shut down is also happening up around 5K rpm, sometimes with the ESP light, sometimes without. Only lasts for a second, less if I let of the pedal.
Needs to go in this week for maintanence anyway.
[B)]
Old 09-12-2005, 01:01 PM   #5 (permalink)
Traction on take off much better. The car still has throttle shut down issues, even at 60mph, merging onto the interstate, if the gas pedal is half way down. Just made appointment to tkae her in Thursday, of this week.
