Old 04-03-2007, 12:55 AM   #241 (permalink)
Date registered: Mar 2007
Vehicle: Honda S2000, CLK320
Send a message via AIM to djdorifto
little tease of the new car in our family...
djdorifto is offline   Reply With Quote
Old 04-03-2007, 07:13 AM   #242 (permalink)
Originally Posted by da_guitarist
Mine were 19x9.5 rear w/ an et40 offset and I used a H&R 10mm spacer on each side. Here are 2 pics of my car from the rear and down the side. i think the offset worked out nicely.
So, I would suggest you getting 2 H&R hubcentric spacers at 5mm, a 5mm spacer for each side. They're 50 bucks a pair on h&r's website (hrsprings.com). The ones on ebay seem ghetto to me. I don't think you'll even have to get longer bolts for the 5mm spacers. probably just stick em in. I think wider than 5 might be a little much. Mine looks perfect w/ 40 offset and 10 mm spacer. Slightly aggressive, but not over the top
thats exactly what i want too - are you sure the 5mm would be enough beacuse it seems such a small spacer but you have more experience so i guessing ill go for it. you think 10mm would be far too much right?
chrisbala is offline   Reply With Quote
Old 04-03-2007, 07:25 AM   #243 (permalink)
i've just got off the phone to a guy that specialises in spacers over here and he advises not to go for the 5 mm as it is not very good and says to go for the 10mm hub-centric spacers - and of course get new bolts. would this stick the wheels out too much or would it look alright?
cheers
Old 04-03-2007, 10:27 AM   #244 (permalink)
da_guitarist's Avatar
Date registered: Aug 2006
Vehicle: 01 CLK55
Well, i dont think the 10 would be way too much. after all, think about how much difference there is between 5 and 10 mm. That's like half your pinky nail. So it shouldn't be a big deal to use 10. might even look better. if you want it to be significant, go w/ 10. The 5 will make little difference.
da_guitarist is online now   Reply With Quote
Old 04-03-2007, 04:24 PM   #245 (permalink)
so i might just go with the 10mm then - it won't stick out too much would it as it would then effectively make the wheel an ET25
Old 04-04-2007, 12:30 AM   #246 (permalink)
Vehicle: 01 CLK55
I like the way mine looks, and 5 mm (a quarter of an inch) won't make much difference. It will look great w/ a 10mm spacer. Def an improvement.
Old 04-05-2007, 11:33 AM   #247 (permalink)
just a few more shots showing the HID
jus a few more pics..deciding to go with the 10mm spacers soon.
going to put #1 pads in the front,
still not sure about the body kit - any ideas guys or comments will be helpful
cheers
Old 04-06-2007, 06:02 AM   #248 (permalink)
okay, i've finally decided- going to go for the AMG rear bumper and sideskirts with a carlsson lip front spoiler for a little bit more of an aggressive look. Do you guys think this will flow?
Any thoughts and comments much appreciated
Old 04-06-2007, 06:30 AM   #249 (permalink)
www.mbsca.com's Avatar
Date registered: May 2004
Vehicle: CL500
Send a message via MSN to www.mbsca.com
I really recomend the one I have together with the AMG sides and back....
Chris
www.mbscashopen.com
www.mbsca.com is offline   Reply With Quote
Old 04-06-2007, 08:02 AM   #250 (permalink)
yeh i was considering that also - you said the fitment was good and that was my only concern. I will be getting the kit in a bout a months time so I will let you know - can i can order from you?
