Old 08-25-2005, 02:55 PM   #11 (permalink)
Portillos beef.....dipped
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK GoPed and a coupla Volvo semi's, c'mawn?
RE: What?
Phade - 8/25/2005 3:15 PM
how easy is it to switch out the bulbs for the inner lights thrill? and where can i buy em ? i can't seem to find the thread you had posting about this..
http://forums.mbnz.org/forums/forums/thread-view.asp?tid=1215852&posts=21
-Pointless liar and inventor of the Bizzy Buzz Buzz.
Silence is Golden, Duct Tape is Silver.
ThrillKill is offline   Reply With Quote
Old 08-25-2005, 03:09 PM   #12 (permalink)
jtbeche's Avatar
Date registered: May 2005
Vehicle: I used to drive a CLK
RE: What?
I think I need to make the trek about 2 hours north more often and have you work on my car. ha ha
The Thrill is gone.
jtbeche is offline   Reply With Quote
Old 08-25-2005, 03:44 PM   #13 (permalink)
W208Cab's Avatar
Date registered: Aug 2005
Vehicle: CLK320 Con, S320L
Send a message via AIM to W208Cab
RE: What?
I wish you were my neighbor too, Thrill. Nice work, you've done what other people don't even think about.
W208Cab is offline   Reply With Quote
Old 08-25-2005, 03:50 PM   #14 (permalink)
Newb Alert
Phade's Avatar
Date registered: Jun 2004
Vehicle: 2000 CLK 430
Send a message via AIM to Phade Send a message via Skype™ to Phade
RE: What?
thrill what do you mean by led load equalizer and file off the contacts sorry if this is a gay question..
At night my thirdeye is as bright as a streetlamp.
AOL: Carl
email: Carl@dopeslang.com
Phade is offline   Reply With Quote
Old 08-25-2005, 04:34 PM   #15 (permalink)
Vehicle: 2002 CLK 55 AMG
RE: What?
You need to use a Load Equalizer so you don't get that pesky Bulb is out malfunction when using LEDS.
You have to file off one of the prongs on the
LED to fit it into the socket.
sfdjmark is offline   Reply With Quote
Old 08-25-2005, 04:36 PM   #16 (permalink)
ThrillKill's Avatar
RE: What?
Phade - 8/25/2005 4:50 PM
There are no gay questions........unless you asked me to go dancing........That would be gay.
The problem with led's is they draw very little current which in turn gives you the "bad bulb" warning, The load equalizer pulls the necessary amount of current to make your ECU think it's an incandescent bulb, which you have in there now. You don't HAVE to have it but you'll get the warning every time you turn on your lights.
About the contacts. The leds I used have 2 prongs on them which are not matched to the bulbs you have in there now. By grinding off one of them, it fits perfectly. If you don't grind it, you'll break the socket in the light. Someone said there is an led with the correct contact configuration, but I haven’t seen one, and the ones I have are the brightest I believe, although they are not as bright as my projectors now [:0]. Can you say high beam projector retrofit?.....Sure, I knew you could neighbor.
Old 08-25-2005, 04:40 PM   #17 (permalink)
ThrillKill's Avatar
RE: What?
DOH!! No clear city light lenses......Maybe fogs then......hmmmmmm? OH SHIT! What about those cop strobes in the fog lights.....Too weird? When you put on your hazard lights they would do that cop strobe light "pull it over, buddy" thing.
Old 08-25-2005, 04:48 PM   #18 (permalink)
Newb Alert
Phade's Avatar
RE: What?
so what do i walk into pep boys and ask for a led load equalizer?
Old 08-25-2005, 04:55 PM   #19 (permalink)
Vehicle: 2002 CLK 55 AMG Cab
RE: What?
I have seen them for sale at most Harley shops, and aftermarket motorcycle merchants. The led upgrade on street bikes is a common trick. They are 12V systems too, so it should make them easy to purchase for our Benz upgrades.
[:D]
indyhiggie is offline   Reply With Quote
Old 08-25-2005, 05:09 PM   #20 (permalink)
RE: What?
You can buy the Load Equalizers from www.autolumination.com
