Old 07-30-2005, 12:00 AM   #1 (permalink)
Date registered: Jun 2005
Vehicle: 99 CLK 430
Can anyone identify this wheel??
I bought the car used with these wheels already installed. I've got a steering wheel vibration/frame shimmy between 50 and 60mph and the dealer tells me I have "a few bent wheels." Very helpful huh? Well, I'm trying to find a replacement for these but I can't find them anywhere.
eBay has a ton of them but all are chromed. Any help would be great guys!
flynavy987 is offline   Reply With Quote
Old 07-30-2005, 06:27 AM   #2 (permalink)
Portillos beef.....dipped
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK GoPed and a coupla Volvo semi's, c'mawn?
RE: Can anyone identify this wheel??
They don't look that bad. Why not get them straightened?
-Pointless liar and inventor of the Bizzy Buzz Buzz.
Silence is Golden, Duct Tape is Silver.
ThrillKill is offline   Reply With Quote
Old 07-30-2005, 07:40 AM   #3 (permalink)
Vehicle: 99 CLK 430
Actually, because I didn't know you could do that. Any ideas on places that would do it? Thanks!
Old 07-30-2005, 07:59 AM   #4 (permalink)
ThrillKill's Avatar
State your location, I'm sure there are members near you who would know.
Old 07-30-2005, 08:10 AM   #5 (permalink)
Vehicle: 99 CLK 430
Doubt anyone is from South Texas... Corpus Christi to be precise. I'm not totally convinced its my wheels anyway.
So before a road trip, I decided it might be time to rotate the wheels. Not the best idea. I put the rears on the front and as soon as I put it in reverse, I realized I shouldn't have. The rears were an inch or so wider than the fronts. I guess there was less clearance in the front and the tires started rubbing. Ever since that, I've had the vibration in the front end. I took it to the dealer thinking a weight must have fallen off. They told me the wheels were out of balance and also slightly bent.
I've never hit a curb but I have come to find out these whels might be cheaper replicas. However, I know it didn't shimmy before I attempted to rotate the wheels and that did not bend them for sure.
Any ideas?
Old 07-30-2005, 09:05 AM   #6 (permalink)
BenzWorld W208 Host
Date registered: May 2005
In the UK these wheels were on some of the old shape SL's. They are currently avaiable at the Merc dealerships. I am not sure if the US Market would supply the same wheels.
600600 is offline   Reply With Quote
Old 07-30-2005, 09:37 AM   #7 (permalink)
ThrillKill's Avatar
Well those are apparently staggered (wider in back than front) I hope you put them back in the right place[:0]. Have you had an alignment? Does the shimmy get worse with speed? That is the classic complaint of an untrue rim however it could be as easy as an unbalanced wheel or worn tire. Good things have been said about this company http://fixrim.com/index.htm They have 3 Texas locations, although if those are replicas you could relace them with new tires for less than $2k.
Old 07-30-2005, 02:42 PM   #8 (permalink)
Vehicle: 99 CLK 430
Thanks for the replies gents.
I did have the wheels balanced but no alignment as of yet. Since it was just fine before I attempted to rotate the wheels, I didn't think it was necessary. The tires also have great tread so I think I can rule that out.
I think a 4 wheel replacement with quality stuff might be in order. I'd just hate to get new wheels/tires only to find the problem still exists.
The shimmy is only between 50 and 60 or so. I can tell the frequency becomes too high at greater speeds to be really noticeable.
Thanks again for the continued help.
