Old 07-26-2005, 06:35 PM   #1 (permalink)
Date registered: Jul 2005
Please help ABS/ASR Lights!!!!
I was wondering if I can have some help, I have a 98 clk320 and the abs, bas, asr lights came on. I tried to reset the car, but it didnt work. so now I'm stuck. Should I go to the MB dealer and let them check it out? How much do you think it will cost to get the lights cleared? Also my srs lights came on too. I dont know whats wrong with my car.[xx(] Someone please help!
Thanks
Kambosoup978 is offline   Reply With Quote
Old 07-26-2005, 07:11 PM   #2 (permalink)
JoshKeaton's Avatar
Date registered: Dec 2002
RE: Please help ABS/ASR Lights!!!!
I don't know if this works on pre-2000 cars, but did you try turning the wheels all the way to one lock, then turning it all the way to the other one and then bringing it back to center?
JoshKeaton is offline   Reply With Quote
Old 07-26-2005, 07:18 PM   #3 (permalink)
Yes I tried that, but nope didnt work.
Old 07-26-2005, 08:54 PM   #4 (permalink)
Portillos beef.....dipped
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK GoPed and a coupla Volvo semi's, c'mawn?
Welcome to Benzworld:
Did you do any recent work to the car that may have triggered it? It may be a faulty sensor on the brakes. I'm having the same issue. Comes on mostly on slow corners or when I exit the highway and slow down. If the sensors detect one wheel is rotating faster than the others this will trigger it. Get on the highway and punch it. See if the lights go off, then see what happpens when you slow down. Keep us posted.
-Pointless liar and inventor of the Bizzy Buzz Buzz.
Silence is Golden, Duct Tape is Silver.
ThrillKill is offline   Reply With Quote
Old 07-27-2005, 11:36 AM   #5 (permalink)
Date registered: Nov 2003
Vehicle: Slow benz
If your alignment is off you will also get those lights going off.
blackbenzz is offline   Reply With Quote
Old 07-27-2005, 12:20 PM   #6 (permalink)
BenzWorld W208 Host
Date registered: May 2005
This too is happening with my car it happens every time i get work done on my car. The dealership has already re-set the computer once but its back on again!
600600 is offline   Reply With Quote
Old 07-27-2005, 12:41 PM   #7 (permalink)
ThrillKill's Avatar
In my case the dealership said the alignment was perfect. I'm thinking it may be a camber issue.
Old 07-27-2005, 01:54 PM   #8 (permalink)
Vehicle: Slow benz
Well camber should be adjusted as part of the alignment.
Old 07-27-2005, 03:57 PM   #9 (permalink)
how much do you think the dealer is going to charge, to get the lights reset. the abs,bas/asr, and the srs light? is there any other way to get rid of these lights.
thanks
Old 07-27-2005, 04:21 PM   #10 (permalink)
ThrillKill's Avatar
The lights are there for a reason. If they're lit, your brake assist is not working. Do you just want to clear the lights?
