Old 02-08-2004, 07:01 PM   #1 (permalink)
Date registered: Feb 2004
Help installed aftermarket HID kit in 04' CLK and the kit wigs out and..
THE LIGHTS FLICKER AND THE DASH HAS 2 MALFUNCTIONS RIGHT AND LEFT HEADLIGHT OUT. DO YOU GUYS HAVE A VAG OR SOMETHING TO TAKE THAT OUT?? OR REPROGRAM THE COMPUTER FOR HID'S??? THANKS.....!!!! PLEASE E-MAIL IF YOU HAVE THE ANSWER I AM LOOKING FOR!!
1FastS4.com is offline   Reply With Quote
Old 02-08-2004, 09:19 PM   #2 (permalink)
Calclearbra's Avatar
Date registered: Dec 2003
Vehicle: 2004 CLK 320 Cab
Send a message via AIM to Calclearbra
RE: Help installed aftermarket HID kit in 04' CLK and the kit wigs out and..
I asked the similar question to the member that is selling HID kits in the classified section and the answer I got was that there needed to be reprogramming so that the voltage was correct (or something like that) or else the lights would just flicker. Hopefully there is a member here that can be more specific but I think you're almost there. It was recommended to me that if I installed aftermarket HID's on my 04 320 cab, I would need to take it to a qualified Benz service center (not the dealership) to reprogram so the lights would work properly. Pleaselet us know what you come up with.
BTW...where'd you buy this kit from and did you check with them?
Calclearbra is offline   Reply With Quote
Old 01-31-2007, 10:16 PM   #3 (permalink)
Date registered: Jan 2007
Vehicle: 99 ML320, 02 ML55, 95 740i, 85 745i
Depending on the wiring harness you are using there may be an easy fix. Can you show me how your wiring harness? Are you using the type that has one harness for both headlights or two?
I had the same problem and it was solved with a new wiring harness and canceller. If the wiring harness is correct and you are using a canceller you do not need to go to the dealer for programming.
ecartoys is offline   Reply With Quote
Old 02-01-2007, 12:26 PM   #4 (permalink)
ExEngineer's Avatar
Date registered: Sep 2005
Vehicle: '02 CLK55
Wow. I almost tried to help Calclearbra out until I realized the thread was 3 years old...
Movin' on...
ExEngineer is offline   Reply With Quote
Old 02-01-2007, 03:58 PM   #5 (permalink)
LOL I only realized it after I made the post.
